Results 1 to 7 of 7
Thread: UNIT SIZE?
    May 2005
    Hmm UNIT SIZE?
    Aside from the compressor name plate and NO TXV, how else can you find out what size a packaged unit is w/o a unit name palte?
    Mar 2011
    Central Florida
    I've seen some evap coils with production quality control sticker telling the coil size. Other than that IF you have serial number you can call the supplyhouse even without model# and they will tell you.
    I guess if you have a metering device you may try calling the supplyhouse with the metering device size to see if they can "come up with something" but its really as good as guessing by the size of the house (not too good).
    TXV and reversing valves
    Quote Originally Posted by txcanes13 View Post
    should not be used to check equipment tonage. They are often different from tonage of compressor.
    Mar 2011
    Central Florida
    I agree but if you have the compressor model you may get lucky calling the distributor for that brand and they finding the only packaged unit in their line that uses such compressor.
    Mar 2011
    Central Florida
    BTW, why do you need tonage of system? if you don't mind.
    If the unit lost all tags, then it must be old.
    If just to repair it, then who cares what size.
    If replace it, then you best to use the "Better guess" called "load cal"
    Mar 2011
    Central Florida
    Quote Originally Posted by just_opinion View Post
    Hence my last question. LMAO
