Results 1 to 13 of 14
09-25-2011, 09:19 PM #1
manitowoc bd 600 partial evap fill..
upper left corner, not low on freon..im guessing its a evaporator coming apart??
09-25-2011, 09:48 PM #2
- Jan 2010
- 72
Are there any cracked peaces of plastic causing the water to not flow properly.
09-26-2011, 12:24 AM #3
everything is fine!! it just wont make ice in that corner!
and when it goes into harvest the ice thats made wont fall
so im thinking the lines in the back of the evaporator have come loose.
09-26-2011, 07:35 AM #4
If the nickel is still on the evap in that area, i would say seperation is a good assumption.
Every customer you take for granted today will be someone else's tomorrow.
09-26-2011, 07:36 AM #5“If You Can Dodge A Wrench You Can Dodge A Ball”
09-26-2011, 10:16 AM #6
ive seen worse evaporators as far as nickle thats left..
thanks itsiceman, ill try the bulb thing..
11-23-2011, 06:21 PM #7
well i thought someone told me to use a tennis ball, but i dont see that post...anyway it worked!! runs like a striped a$$ ape!
11-23-2011, 10:59 PM #8
I think it was in another post but the tennis ball was all you bro LOL
Glad it worked
11-23-2011, 11:03 PM #9
I'm curious. What did I miss?
Local 597 Service Fitter
Metal Trade Journeyman
PAY ME NOW OR PAY ME LATER
It was working when I left...
WWFD
11-23-2011, 11:12 PM #10
Is your PM turned off 2sac?
11-23-2011, 11:22 PM #11
I don't think so. How would I know?
WWFD
11-23-2011, 11:25 PM #12
I think I figured out the PM. Should be turned on.
WWFD
11-23-2011, 11:37 PM #13
It shows as an option to send you one now but it still wont let me.
I'll take a look for the other thread but I think it was about mechanically holding a tubing separation to the plate when the solder has come loose.“If You Can Dodge A Wrench You Can Dodge A Ball”
