Results 1 to 6 of 6
Thread: coil cleaning
    coil cleaning
    I am currently working on a rtu set on grade, serving a powder coated paint room. It is ten years old and has a very restricted evap coil. My question is what do I use to clean this residue from this process from between the fins of the evap. Water does not seem to work. They use acetone to clean the residue from the spray nozzles.
    Aug 2008
    Wink
    I use United 372 exterior coil cleaner you mix what ratio you want in a sprayer. For smaller coils I use United 166 Power Up foaming no rinse. Its lemon scented and works excellent.
    Aug 2008
    Quote Originally Posted by Jobe Justice View Post
    What do you mean by "spray nozzles"
    Mount Airy, MD
    Quote Originally Posted by Hardwater View Post
    The Paint Nozzles
    Mount Airy, MD
    This should be a 100% outside air/other then paint booth air going through your evaporator....
    Are you pulling air from the space with dust, dirt and ???
    OR
    Are you pulling in outside air ???
    Please tell us that you are NOT pulling air in from the booth
    Aug 2008
    Lightbulb
    Quote Originally Posted by Chris_Worthington View Post
    OR
    Surley someone wouldn't pull return from a paint booth or would they?
