Results 1 to 11 of 11
    Apr 2010
    Honeywell FocusPRO TH5110D
    I'm trying to find out what this thermostat cost.
    It's included in the proposal, but I really don't need it.
    So, if I decline the TH5110D, how much would it knock of the proposal?
    Thanks.
    Hope this doesn't violate any rules.
    Quote Originally Posted by oldgoodman View Post
    Thanks.
    information on pricing is not permitted but explain your thoughts to your dealer and have them issue you credit on the proposal
    Southeastern Pa
    The Focus Pro stats provide a great value for the dollar. Deleting it would not decrease your cost significantly if you are getting new equipment installed.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Apr 2010
    Quote Originally Posted by timebuilder View Post
    You're right as I googled the item, might as well go with it.
    Thanks.
    Southeastern Pa
    Plus, since your contractor installs the stat, you may be covered with a warranty on the Focus Pro as well.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Apr 2010
    Am I correct in that only pros can purchase these?
    Can't get them at the regular home improvement places?
    They are available to the public but you should purchase it from your dealer and have them install it and set it up for you.
    Grand Rapids, MI
    this t-stat is avaible with a larger display than avgerage, please have the contractor install it for a better warranty.
    luck dan
    Virginia
    I would go with the focus pro 6000 it's the same as the 5000 but the programmable version
    I'd go with the communicating thermostat for that communicating furnace you have.
    Saint Augustine, Florida, United States
    Let the contractor you trust to heat and cool your home install the proper t'stat. Everything will be warranted. Peace of mind.
