Results 1 to 9 of 9
Thread: Thermostat ?
    Jun 2011
    Blue grass KY.
    Thermostat ?
    We went to do a service call today. The house is huge The home owner wants to move the thermostat to his room because stays warmer there then any other place in the house . He already has 4 registers on the room. The problem is there is no way to run a stat wire to his room . Is there like a wireless thermostat that we can put in his room and do away the one he already has?
    Altmar, New York, United States
    why not find the root of the problem?
    Jan 2011
    greenville , sc
    Quote Originally Posted by captain71 View Post
    try this http://yourhome.honeywell.com/home/P...s+FocusPRO.htm
    johnstone or ccdickson.
    catch a man a fish , feed him for a day.
    teach a man to fish , ruin a good business opportunity.
    Apr 2008
    TEXAS
    is there a return in this 4 supply room?? if not, no tstat is gonna be accurate for total home comfort. he may just be dumping mass amounts of air into one room, making it warmer/cooler than the rest of the house.
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    May 2008
    New Mexico
    T-stats just tell the unit how long to stay on / to meet set point.
    Is the heater size correct/what about heater output/cfm/ many factors
    to check out .What is the temp. at the supply vents?
    Good Luck
    Delaware
    Smitty has it pegged....................you need a return or at least a transfer duct.
    Always here
    Jun 2011
    Blue grass KY.
    Quote Originally Posted by smittyii View Post
    Yes they have a return in that room They have a 14x14. The way this house is built there is no way to add or change anything in this house this house is 12,500 square feet. this house has 6 units in it.
    Jun 2011
    Blue grass KY.
    Quote Originally Posted by snupytcb View Post
    The way this house is built the trunk line runs in the basement and the basement has sheetrock. We tried closing other vents to help that room but he said that didnt help. we ware going to change the duct work and put 7 inch runs but no way to change it everything is enclosed I dont know if closing the return will help any.
    Philadelphia, PA
    Closing the return will most likely make it worse. Have you measured the airflow to that room? As others have said, moving the stat will make the unit run longer to cool that room which will make the others cooler.
