Thread: Tankless Water Heaters
12-24-2005, 10:53 AM #1
Regular Member - bad email address Contact Admin
- Jun 2001
- 95
The facility I work for has a commercial size kitchen with a total of 20 hot/cold faucets (this includes 4 bathrooms)a commercial size dishwasher, and one residencial size washer/dryer. Would a tankless water heater work in this size facility? It is presently supplied by a Parker WH-300 Hot Water Boiler which has a leak in the tube bundle and is 25 years old. We want to apply best Energy Effecient System.
Thanks for suggestions.
(a blue collar maintenance guy)
12-24-2005, 12:10 PM #2
It would work but you would need to calculate the GPM requirements for worst case situation and then match it with the corresponding # of tankless heaters.I have one in my house and it flows 8 GPM, so you would need possibly 6 of these .Your gas line would not be large enough and the venting is expensive.Most commercial applications , they would put these outside and pipe water up(cheaper).
12-24-2005, 12:18 PM #3
- Mar 2001
- 1,213
DHW
Why not use a gas boiler (Modcon) & storage tank?
12-24-2005, 06:05 PM #4
- Nov 2005
- 132
[Edited by mfi on 12-24-2005 at 06:12 PM]
12-24-2005, 06:11 PM #5
- Nov 2005
- 132
How about electric ones. They can flow up to 12 gpm's depending on the delta T you need.
