Results 1 to 11 of 11
    Houston and Katy
    Need gate parts on York VFD
    I have a blown gate on a 500 hp York VFD (phase B inverter section) The assembly is 371-1486-101. There are four gates on the board and each has it's own driver. Gate number two cracked and shorted.
    Looking for a replacement gate - new or used. Tried to buy a new section form York but they claim it is not a replacement part.? Suggested new drive.
    Dec 2008
    Dixiana, AL
    If you're talking about the IGBT, that's not a replacement part that would be available from jci. But why would you need a new drive? Get the output pole assembly and change it.
    North Carolina
    Try P#371-04164-001 power module kit (aka - IGBT). Also, if you have not already, test your scr's,capacitors, and trigger board. By the way its expensive as h#@!
    Chad
    Somewhere in the world.
    VSD Parts
    I find that hard to believe but then again anything is possible with JCI these days they just want to sell equipment for big bucks.
    PS: Here is a parts book for a VSD.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Houston and Katy
    Quote Originally Posted by klove View Post
    The IGBT (I call it a gate) is a Siemens BSM150GB120DN2. The B-phase gate #2 of 4 looks like it internally shorted against the heat sink. Found used listed in Ebay for about $20 each. Could not find a local source for new part.
    I tested resistors and caps - all good. I do not have a troubleshooting guide for the driver board but it should post a code on power up if it is bad.
    Houston and Katy
    Quote Originally Posted by york56 View Post
    Thanks for the pdf.
    I buy JCI controls because they have great docs online. York is still in the dark when it comes to public literature so I buy Carrier equipment. They have way more info published on their site.
    Houston and Katy
    Quote Originally Posted by chad_nc View Post
    Chad
    I am working on a YK drive. just need the gate only, everything else was good
    couldn't find new so off to Ebay -
    http://www.ebay.com/itm/Siemens-IGBT...item2a00e6a66c
    Jul 2011
    Columbus, Ohio
    Finally the day has come when you can buy your used VFD parts on E-bay.
    North Carolina
    Quote Originally Posted by rellufnalla View Post
    I know you are working on a YK, You said that in your op. The part you are describing Sounds like Part #27 on page 25 of the renewal parts list that York 56 posted. There is a parts counter in houston at the JCI branch. Take them that part # and they will gladly order it for you. They dont sell the transitors and the gate board seperate, it is all one part.
    good old Europe
    I think it is better to contact the spare parts department with the type and serial number of the vsd available. To many different drives and revisions are out there. The spare parts manual uploaded by York56 just covers the "Vyper" drive. A burned IGBT is considered as a catastrophic failure and just changeing the IGBT might not resolve the source of the problem. A new IGBT could be killed quickly again (they are not cheap!). I think working on the York VSD requires a factory training or at least reasonable experience with the equipment. I would never take used spare parts on such equipment if i personally havent removed it from some other working drive.
    "Quality exists, when the price is long forgotten."
    Henry Royce
    Quote Originally Posted by Entropie View Post
    I agree fully with Entropie on this post that is why a full M/N & S/N is so important to get the right information for the right piece of equipment that your working on you can get seriously hurt working on this piece of equipment.
