Results 1 to 13 of 42
09-20-2011, 03:15 PM #1
New Guest
- Sep 2011
- 4
Oh please help me with my HVAC quotes
I promise not to rhyme any more but some help would be a score. If we find your help valuable enough in our decision, I may even send you a gift card for beer.
We are in the process of getting bids
for a new HVAC system. About us: 3000 sq ft 2-story house in southern Maryland. We currently have a propane furnace with AC unit. No heat pump. We are considering a hybrid but also wondering if we should just go heat pump. Our crystal ball is broke
so we are not sure how long we will be here. We do have a full gas tank with about Removed Pricing worth of propane in it
- but we won't really factor that in our decision. The only other thing on gas is our oven.
Here are our quotes:
Quote 1:
Heat Pump: Carrier 25HNB648
Furnace: Carrier M-58MVC120-20
Coil: Carrier CNPV6124A
I can't quote the ton, seer or AFUE or btus (assume the 120 is just that). He talked all this stuff and had it in his notes but didn�t put it in the quote. I don't think he is hiding anything just didn't put it on there. I'm not feelin all that well so my google skills aren't producing.
Included in this quote: Complete ToraVac Source Removal System (is this duct cleaning? If so, it is not included and extra
10 year parts, 2 year labor, 10 year compressor, 20 year heat exchanger warranty
Before rebates, claiming $XXX fed tax credit, $XXXX Carrier rebate, $XXX SMECO (local electric co-op) rebate
Quote 2:
Heat Pump: Carrier 2HBC360W003 2 speed 4.5 � 5 ton
Furnace: Carrier 58MVC120-20 95% modulating gas valve variable speed fan 120,000 btu
Coil: Carrier CNPV6024ATA
Seer: 15
Warranty indicates 10 year limited parts warranty through Carrier
Company indicates repair or replace free of labor charge any parts on the new system found to be defective for a period of 2 years.
Claiming $XXX tax credit, $XXX Carrier rebate, $XXX SMECO rebate
Quote 3 (same company as #2)
no rebates
Quote 4
Install New 16 Seer Carrier Comfort Series Air Conditioner + Coil with new 90% 120,000 btu gas furnace
Claiming $XXX fed, $XXX SMECO rebates
This guy also pushed a Heil hybrid which we are not entertaining
I'm not sure why the difference in tax credits and rebates from SMECO but might be based on efficiency.
First off which of these units seem appropriate for our situation or are their other options we should be considering. Any insight on the quotes in any shape or form is appreciated. Prices of #1 and #2 were comparable.
From,
Merrie Beth in somd
09-20-2011, 03:23 PM #2
Please hit that little "edit" button under your post and remove all prices. Prices are not allowed on this forum. You may want to read the rules before further posting. Somebody will be along soon to answer your questions.
An answer without a question is meaningless.
Information without understanding is useless.
You can lead a horse to water............
http://www.mohomeenergyaudits.com
09-20-2011, 03:28 PM #3
what kind of labor warranty does each company give? where are the units going to be installed in a crawl space or attic or mechanical closet these all have bearing on the longevity of the unit as a whole...
catch a man a fish , feed him for a day.
teach a man to fish , ruin a good business opportunity.
09-20-2011, 03:31 PM #4
New Guest
- Sep 2011
- 4
09-20-2011, 03:42 PM #5
New Guest
- Sep 2011
- 4
Quote 1: 2 years labor; he did also have this:
If the compressor in your ac fails once in the first 5 years install a new outside unit; if the heat exchanger in your furnace fails in first 10 years we will install a new furnace; depending on the system guarantee savings of 10-35% will refund double the difference of your savings not realized during the first year; if your system breaks down in the first year leaving you without heating or cooling and they fail same day repair we receive $500, same if they don't have it operating on the day promised.
Quote 2 doesn't seem to indicate in writing - thanks for the heads up, we'll want to see this.
This will be downstairs in a mechanical closet just next to outdoor wall which is where the compressor is.
Appreciate your time and insight!
09-20-2011, 05:02 PM #6
Professional Member*
- Jun 2011
- Wake Forest, NC
- 351
Maybe this is just me, but a 120K furnace raises my eyebrows a bit... I'm not sure based on what I read that you need that much junk in your trunk.
It's not rocket-science...
It's electromechanical thermodynamic engineering
09-20-2011, 07:21 PM #7
Just so you are comparing apples to apples, Heil premium equipment is the same as Carrier.
09-20-2011, 07:48 PM #8
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
did any of them perform a manual J on this structure?
or did i miss it in the post?
09-20-2011, 08:44 PM #9
- Jan 2002
- East Grand Forks, MN
- 1,361
High!
120,000 furnace; that seems high considering you are in Maryland. For example, up here a 60,000 can be enough for a 3000sq ft new house and maybe a 80,000 for a 50 year old house!! It seem very Questionable?
Just don't let them oversize, it really does matter.
And I haven't even mentioned the cooling load yet.
09-20-2011, 09:44 PM #10
- Feb 2011
- North East Ohio
- 653
equipment seems oversized to me too. I would ask your contractors to do a load calc. to be sure you get properly sized equipment
09-30-2011, 12:24 PM #11
New Guest
- Sep 2011
- 4
We have asked several folks regarding the size of the unit and feel confident that 5 ton is needed based on the layout and size of the house - and in order to get a match the 120btu Carrier unit is necessary.
Can I throw one more in the mix?
Amana 18 seer Heat Pump ASZ18 with AMV 95 (might be 96) - 115 btu. Amana 5 ton cooling coil.
This unit is coming in quite a bit lower than the others, so what gives? Is Amana compromising on quality?
Thanks again for all the input
09-30-2011, 01:00 PM #12
- Mar 2006
- The South
- 1,860
Merribeth
I prefer the Carrier over the Amana.
And with the Carrier I would not go over the MVC 100 K model furnace without some supporting document like a Man J load calc.
IMO
09-30-2011, 03:08 PM #13
New Guest
- Jun 2011
- Chicago Illinois
- 5
1
