Results 1 to 13 of 25
    Sep 2011
    Milford, MI
    Boiler sooting up are we dying from CO
    I'm new to the forum and could use your help. I have a 5 year old (to the day) Slant Fin boiler (model se70dp). Our old boiler was at least 45 years old. When they replaced it was in bad condition. Service man stated Flu pipe rotting out, leaking at eliminator and relief vavle. Due to safety issues he recommended replacement. We agreed.
    New boiler installed everything was working for first two years then roll out switched tripped. Service tech says roll out switch open, boiler sooted up, needs mat (?). He quoted us a crazy high price to clean the sooted boiler. We ended up having a different company clean and replace switch. All was well for two years. Now I have been working in my basement on a project and I had to move the boiler. When I took the hood off I see it is completely full of soot and rust again.
    Any suggestions or help please. If the roll out switch goes bad does this mean we are getting CO2 in the house?
    michigan
    Do not take any chances. No one can tell you from here whether or not CO is leaking into your home. Call out a pro and have it tested. I would also recommend that the pro also check that your boiler is getting a proper supply of combustion air, proper combustion analysis done. Good luck.
    Apr 2010
    Minnesota
    Sounds like something may not be burning correctly. Get a company to do a combustion analysis on it to find out why it soots up so fast. Tripping roll out switches is not to be taken lightly.
    Mar 2011
    Edna Bay, Alaska Highest concentration of black bears in the US
    Can you say, Yearly Maintenance?
    Aug 2011
    Ontario
    sooting is usually caused by lack of combustion air, or dirty burners which means that yes it is more than likely spilling Co. You really need to call a pro NOW.
    Sep 2011
    Milford, MI
    Thanks Guys. How about instalation issues? Combustable air mix, is this install related? Why did the original chimmey flu pipe rot out? Could this be venting up my chimmey properly? I have it going into my brick chimmey on the outside of the house. I looked down it from the top and it doesn't seem to be plugged.
    I know you said yearly maintenance and I agree, but every two years a complete rebuild doesn't seem right.
    John
    St Paul, minnesota
    do you have a combustion air duct installed and do you have a flue cap installed?
    Sep 2011
    Milford, MI
    Lost me. I have a mushroom cap about two foot off the top of the boiler and a cap on the top of my chimney.
    St Paul, minnesota
    a combustion air duct is a duct coming from outside and will terminate somewhere near your boiler. a boiler will soot up with a lack of air.
    Are you using nat gas or LP.
    Sep 2011
    Milford, MI
    natural gas.
    Not sure on the combustion air duct? I will look. It is in a low height basement with a outside vented window that I leave open.
    Madison, Wisconsin
    Call the co that installed it and ask if they can do a combustion analysis, if not then find a co that can. How big is the flue in the chimney, and is there anything else sharing the chimney? Did you make the home super tight recently, new windows, doors and so on. The boiler needs the proper amount of combustion air, the right gas pressure and volume, the right flow rate, system pressure, and the right temperature return water. Any one of these things could cause soot.
    In short you need a service man that knows boilers. You could try our contractor locate map..
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Time you had someone out that knows how to set it up right. After its cleaned, it needs to be set up with a combustion analyzer. Just eye balling the flames doesn't tell anyone anything about how well it is or isn't burning.
    The lower priced company you had out, apparently didn't know how to est it up. You need a company that knows what they are dong, and has the proper tools to set it up.
