Results 1 to 13 of 16
Thread: Difference in belts
12-20-2005, 10:15 PM #1
What is the difference in A, B, and 4L belts. Specifically between A and 4L. (this question is a trap)
12-20-2005, 10:33 PM #2
- Aug 2003
- 1,311
most folks dont respond well to things like "I know, do you?"
but 4L (fractional HP) and A belts are pretty interchangeable. there is little difference in the width. the b is bigger than eighter of the preceeding in regards to its width.
Now can you tell me the difference between the 5vx, and a b belt, and a 5vx from a c more specifically?
01-02-2006, 08:46 PM #3
- Apr 2003
- 92
i was told by the owner of a place that sells motors/belts etc. and he told me a A belt was i think 6 times stronger than a 4L belt.
01-02-2006, 09:04 PM #4
- Feb 2004
- Home is Azle Texas, work in Dallas-Fort Worth & surrounding areas.
- 370
Get a Grainger book & look up the details for the belts, there are differences in pitch,width & such. Some of the belt makers also publish data that will help.
Life as an adult is much like life in kindergarten - If I make it through the day without crying or hitting some one, then it was a good day!
01-02-2006, 09:11 PM #5
- Nov 2005
- 4
From weak to strongest and as you go up in strength it requires more tension.
4L - A - AX - 4VX
5L - B - BX - 5VX
Mike
01-03-2006, 01:10 AM #6
Member
- Nov 2004
- Practically Canadian ehh.
- 675
Price?Originally posted by incontrol
LMAO
01-03-2006, 05:06 PM #7
arent they like 2 inches different in length too? Never can remember which way though. Did I win anything?
eventu rerum stolidi didicere magistro
01-03-2006, 05:56 PM #8
- Mar 2004
- New England
- 224
An apprentice is half a journeyman ,two apprentices is a call back.
01-04-2006, 06:18 PM #9
As cg said, there is a difference of 2 inches in length. One is measured around the outer surface, the other is measured around the inner surface. Also the A belt has a deeper pitch or depth. Width is the same.
01-10-2006, 09:41 PM #10
- Jan 2006
- 6
If I need a replacement belt, and there's an A-48 on it, I can use a 4L-500 just fine!
01-11-2006, 07:09 PM #11
Since this is a trick question I'm going to say,
The difference is like water and ice.
It's all made of the same stuff it's just different.
Specifically, ice is just frozen water.
Regards........
01-11-2006, 07:31 PM #12
I needed a B belt, but beings none were available, I put the old trusty Autozone fan belt on it, still running 6 months later,and better sounding. Probably increased the cfm also.
01-12-2006, 12:27 AM #13
- Aug 2003
- 1,311
apparently I stand corrected, they do respond and in respectable numbers! go figure?Originally posted by hvac3901
