Results 1 to 13 of 20
    Sep 2011
    Orlando, Fl
    Who should do Manual J calc?
    My question has to do with industry standard practices. The evaporator coil is leaking on my 9 year old Carrier AC. At 9 years the AC isn't real old but I have had problems with it and decided to replace the system with a 16-18 seer unit. I intend upon getting 3-4 bids for this work.
    One of the contractors gave a price for running the Manual J calc.I don't want to pay for this three times. Should I have an independent run the calcs, or can I get one of the bidding contractors to run the numbers and supply the same print out to all?
    Massachusetts
    some contractors will charge a price to do load calcs, but if you choose them they'll deduct it from quote. Some will even do it for free, but sometimes you get what you paid for.
    It is a good idea to know up front exactly what size equipment is needed so all bids will be apples to apples.
    Sep 2011
    Orlando, Fl
    Thanks. I have a related question. My house is two stories and we have some difficulty balancing the temperature on the second level. The house is well insulated but Orlando can get hot and we use AC year round. Will the Manual J calc help identify any issues with the current ductwork and design?
    Massachusetts
    A manual D is for duct calculations and sizing, that may be helpful for your situation.
    a properly done load calculation should help determine this issue.
    if you continue to go forward with one system, a cone system will help and can help even the tempuratures between upstairs and down.
    apples to apples also includes the type of system, warranties, and efficiencies.
    Sep 2011
    Orlando, Fl
    Thanks for the feedback.
    Ed
    May 2009
    Cool
    Quote Originally Posted by Ed D View Post
    In NC, we are required to do Manual J calcs. It takes about half a day to do them. Would you work for half a day for free?
    SW FL
    Thumbs up Efficiency applies to work process and equipment
    Quote Originally Posted by simplyrollin View Post
    Work Process and type of calc need to be reviewed
    After you perform 6 calcs and use appropriate templates, whole house calcs should take < 20 minutes for house < 2,000 square feet.
    Whole house calcs and room-by-room calcs have distinctly different functions.
    A room-by-room calc can be performed in less than an hour with a little practice.
    Designer Dan
    Jul 2002
    Yuma, AZ
    ...if you continue to go forward with one system, a cone system will help and can help even the tempuratures between upstairs and down. ...
    I almost asked what a cone system was... only to realize you meant ZONE system. and Yes, I agree.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
    Jan 2011
    Ward, Arkansas, United States
    Quote Originally Posted by lynn comstock View Post
    I was scared to ask...thought we had warped into something new.
    "Gentlemen. You can't fight in here. This is the War Room!"-Dr. Strangelove (1964)
    Northeast Ohio
    Quote Originally Posted by dan sw fl View Post
    Have to agree here As far as the OP, Manual J is part of the job but to give you the info up front makes it easy on the c ontractors to follow. I have mixed feelings about charging up front for a Manual J . We do a quick whole house to put us in the ball park for estimate purposes and do a refined Manual J (room by room) when the situation warrants it. We do not supply ANY printed Manual J information until the job is signed, sealed and delivered
    DEM
    Jun 2011
    Wake Forest, NC
    A simple block load for a change out situation should not take more than 30-60 minutes, and we do those for free on any change out we quote. If there is a need to do a room-by-room or a manual D then we do charge for it as it is more labor intensive. We do deduct the cost off the job if it is awarded to us. Minor variations on block loads may occur from one contractor to another so don't be suprised if there is some minor differences. So long as the difference is not more than 5-10% of the total load then I would not worry about it too much.
    If one says, say a cooling load of 34,000 and another says 35,500, dont worry about it. If one says 34,000 and another says 42,000 then someone has something wrong and needs to check their math.
    It's not rocket-science...
    It's electromechanical thermodynamic engineering
    Jan 2001
    Pamnyra VA.
    I found using a distance meter in addition to a tape measure helps you do it faster.Tape measure for windows and doors.
