Page 3 of 3 FirstFirst 123
Results 27 to 37 of 37
  1. #27
    Southeastern Pa
    OP:
    your best course of action is to talk with the service manager and find out what options he will offer you, once you explain this dilemma. Sometimes, when a field tech is not able to find his way, the service manager can visit and set him straight.
    If this is not an option, you may be better served by getting a recommendation for a company from a trusted friend and have THEM come out and have a look. Tell them what you know, and ask what it will take to find out the cause of the problem.
    Then, proceed form there.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #28
    Aug 2011
    North West FL
    "I’d like to thank all you for your input. Unfortunately none of them make me feel very good. The gist seems to be that I wasted a lot of money for a quick fix just so I could stay cool. I wasn’t expecting things to be perfect, but had I known that this fix was going to result in such high head pressures I might have declined. The tech that suggested this combination didn’t tell me that the results would be this bad.
    As a customer I don’t see how this could be my fault and I think I should receive some consideration. I’m just not sure what I can reasonable ask for. "
    It's not your fault that the install tech did not know what he was doing. However, it is in your hands to find a company that can give you what you want. How many bids did you get? How many phone calls did you make? How many reviews did you check? All that could have been done in one tenth of the time it has taken you to try to find a solution to the prob. It sucks that you have to work at finding a good company, but it has to be done. As hard as it is to find someone good, it's harder to find someone that will come back and fix the problem. Esp after you have paid them. Do a good deed and call out someone who knows what they are doing. They will be able to give the answers you need.
    www.mcleanair.com
    "It was working until it quit."
  3. #29
    Do you have any other data on the installation? Compressor amps? Do we even know that the technicians guages where correctly calibrated?
  4. #30
    Quote Originally Posted by McLean Air View Post
    McLean Air,
    Please read and follow AOP forum rules.
    A link to those rules can be found below this post in my signature line
  5. #31
    Winston-Salem NC
    Quote Originally Posted by dandyme View Post
    I'm a little concerned with:
    "The more skilled technician found that the system was overcharged and reduced the charge as much as he could."
    Could of been a case where bringing the high side down left the low side too low, and bringing the suction up, raised the head too much.
    Easy to see that happening with stuff not matched. I'd probably say getting a matched ID Coil, metering device and new line set would solve the problem. How folks figure not matching ID/OD is a good thing, I'll never understand.
  6. #32
    Tallahassee, FL
    Another quick note - Just because the outdoor unit was capable of up to 12 seer does not mean they the installed the higher end air handler. Or the correct piston 16 years ago.
    I mostly find higher end condensors on base line handler designed for the 10seer models.
  7. #33
    Jul 2005
    Quote Originally Posted by SBKold View Post
    In cooling mode a smaller evaporator coil does not cause high head pressure.
  8. #34
    Tallahassee, FL
    Quote Originally Posted by hvacrmedic View Post
    was not my intention to say that
    Usually the handler had the 10seer generic piston ...which would cause installer to overcharge slightly to compensate to get cold back....which can lead to higher head...correct me if im wrong.
  9. #35
    Jul 2005
    That would be incorrect. If you had higher head you'd have a higher PD across the MD, and then you'd be overfeeding the evap and flooding back, would you not?
  10. #36
    Tallahassee, FL
    Of course which is why the additional refrig was added to decrease SH.
    "high" head is generic. I just meant higher than normal.
    I simply posted the origional to mention that just because the condensor was a high seer of its day doesnt mean the handler was.
    The origional 10seer piston would be considerably smaller and will cause you to add more refrig than nameplate states to get desired suction temp and pressure.
  11. #37
    Jul 2005
    Yes, in that case it would run a higher head than what is normal for a 13 SEER condenser. But it would still run lower than what is normal for a 10 SEER. So whether you consider the head pressure high or low, well that depends upon what you're comparing the head pressure to. The OP reported a condenser TD of 32°. Under the conditions he gave that's a high TD even for a 10 SEER. If the coil was originally set up as an 8 SEER match, then I could see the head pressure being the result solely of the present mismatch.
