Results 1 to 13 of 31
12-18-2005, 11:33 PM #1
- Dec 2005
- 25
Need to be set straight. I am on long island, ny where electricity costs a fortune. Building a new house. Is it correct that heat pumps use a lot less electricity than heat strips? My contractor friend seems to think that I should just go with heat strips because of all the additional wear i would be putting on the compressor year round instead of during the summer to run the heat pump. I would like any input......
Philip
12-18-2005, 11:50 PM #2
Well, of course it'll wear out faster running year round vs just in the summer months. But, since it's designed to run it really isn't going to wear out much faster. It's almost impossible to say how long a piece of equipment will live, but even a heat pump should last 10-15 years or much more if it's installed and most importantly taken care of properly.
Energy use is based off of electric heat, that being 100% efficient. A heat pump is generally 200-300% effcient, producing 2-3 watts of energy for every watt used.
A heat pump is a no brainer, especially if you have high electric rates.
12-19-2005, 12:05 AM #3
- Dec 2005
- 25
Rheem and carrier seem to have very efficient models. Are their performance #'s inflated or in your experience are they pretty accurate. The goodman systems are far less expensive but it appears the rheem and carrier high end models would save a lot of money. Is it worth spending the extra dough for these?
12-19-2005, 12:26 AM #4
- Dec 2005
- 44
What is this contractor friend. By doing your homework now could keep your fuel cost low. just a thought, oil is not a dirty word is it.
12-19-2005, 12:42 AM #5
- Dec 2005
- 25
he is a homebuilder but obviously isnt an expert in this stuff like you guys are. We have always had all electric. I do not want oil in my house at all and there is no gas available here.
12-19-2005, 02:43 AM #6
Professional Member*
- Nov 2004
- SW FL
- 5,355
Good Windows, Insulation & High Efficiency
What size house and type of windows that you will be using ?Originally posted by pooka16
Long island, NY where electricity costs a fortune.
New house
Is it correct that heat pumps use a lot less electricity than heat strips? Philip
Rate$ > $0.18/ kW ?
Select Heat Pump 9.0 HSPF/ 16 SEER or better.
I believe that your
time weighted C.O.P. may be close to 3
with somewhat milder temperatures on Long Island.
http://www.trane.com/Residential/Pro...mps/XL16i.aspx
http://www.trane.com/Residential/Pro...ableSpeed.aspx
AND seal the house to minimize infiltration ...
+ achieve < 0.2 A.C.H.
http://www.airtightinsulation.comDesigner Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
12-19-2005, 08:43 AM #7
- Apr 2005
- NE PA
- 697
A heat pump will give you on average 2 to 3 times the heat per KW of electricity as compared to strip heat.
That is a substancial savings as compared to straight electric.
paul
12-19-2005, 11:44 AM #8
- Dec 2005
- 25
The house is 2story 4800 sq ft without the basement which is another 2700sq ft. all windows are schuco triple pane with gas. We are getting spray foam insulation. we are paying $.11 per kw
12-19-2005, 12:02 PM #9
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
With great windows and insulation,insist on a Manual J load calulation,and Manual D duct design,for your comfort!!
Insist!!,if needed youcan do it yourself at the red"hvac calc tab above!!
Read more about them at http://www.acca.org
12-19-2005, 12:14 PM #10
- Dec 2005
- 25
The only difference i see between the xL16 and XL19 is that the XL19 has two compressors........is this worth the added expense? What is D duct?
12-19-2005, 12:46 PM #11
Grumpy Old Man
- Apr 2003
- 6,383
To size the heating equipment to the home, Manual J.
To size the supply/return ducting to each room, Manual D.
These are essential for a proper, efficient, trouble-free system!
02-20-2006, 12:55 AM #12
- Dec 2005
- 25
update...need help again
USed the HVAC calc and coming up with 6 tons for the entire house..... 2 floors and the basement.
I've decided on the heat pump based on everybodys recommendation but the next problem is brand/Seer...
My friend is telling me to go goodman since parts are pretty inexpensive and easy to get. Supposely trane and carrier arent for the do it yourself person and they wont honor the warranty if a licensed installer doesnt do the work...... The highest seer on a goodman is 14 where as the trane/carrier is 19......is it worth the extra expense?? Any thoughts would be greatly appreciated!
Philip
02-20-2006, 01:02 AM #13
If your going to do it yourself, use goodman
