Thread: 10 ton,
    Hey guys, How are you all? I have a RTU that won't ignite. I changed the ignitor board, and a ste up, crazy leg transformer (120v pri & 230v sec). The only things after thar are the UCP board, gas valve, glo plug & roll out. Please HELP!!!
    Houston,Tx.
    Welcome but were probably going to need a lot more info:
    Brand,mod# for starters.
    One Post at a time on one subject please.
    khw71471
    Need a solution for a rtu giving me a hard time. YCD120 Voyager Series. The UCP Board, gas valve and hi limit are the only controls left to swap out. Help!! Why won't i get fire?
    12-19-2005 06:13 AM IP: Logged
    rtu
    You would get more responses in "commercial" section.
    What I/C do you have Texas or Fenwall?
    Whats your cold ohms on HSI?
    What voltage are you getting to HSI?
    12-19-2005 07:03 AM IP: Logged
    Nov 2005
    more info .. what exactly happens during heat demand ? i could help u possibly if u werent giving bits & pieces
