Results 1 to 11 of 11
    Dec 2010
    Woodbridge Twp, NJ
    Thinds that make you go HMMMMM
    Head chef gets fired on Friday
    I get called in on Monday....hmmmmm
    Every customer you take for granted today will be someone else's tomorrow.
    michigan
    Ok, I give. Who installed it..........looks to be brand new. Might have a hard time breathing
    Mar 2006
    have you ever tried to inhale and exhale at the same time, its ****ing awsome
    Jun 2010
    North Fl
    Ok OK OK I'm a idiot and I don't work of these much but whats wrong????
    HOW MUCH DID YOU SAY???
    Mar 2010
    Arnold, Mo
    Confused
    It looks like there's plastic wrapped around the fans.
    Dec 2010
    Down by the river
    poor photography, I really did not see that till it was just pointed out, I was looking more to the fact there is no room in front of the coil.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Jan 2011
    greenville , sc
    whaa. so the chef did it? im confused. whats the slimey stuff in front of the evap coil . is the cooler THAT nasty?
    I don't know
    Jan 2011
    greenville , sc
    Quote Originally Posted by amd View Post
    huh? this tread is getting deep. or not?
    Dec 2010
    Woodbridge Twp, NJ
    The "slimy stuff" is actually the foundation of the place. The head chef was fired because of many things but the last straw was that he kept throwing the kitchen garbage off the back deck right above these condensers.
    All of the screws for the cover were taken out and laid next to the unit and i didnt think of it unit i took the top off.
    Those fans are inducing the draft so the air is blowing towards you so how could the plastic get sucked into that side? To get it in there that way, it would have to have been stuffed into the fans.
    They cant prove it but it seems like a coincedence that this happened shortly after the guy got canned.
    As for the quality of the photography, it's a clear plastic bag taken with a camera phone. i think it looks damn good.
    Aug 2011
    sherman tx
    sureley you jest airflow thru the front of the unit is little to none causing high head pressures
