Results 1 to 13 of 15
    Sep 2011
    coated evaporator repair
    Does anyone have a good prodoct to seal a small leak on a coated evaporator? I have a pinhole on an evaporator in a beverage air prep refer,would rather not have to remove vinyl protective coating if possible. Would an epoxy sealant over the coating be acceptable? The leak is on the u-bend of the evaporator.
    Kingston, Ny
    They used to have a product called 'techinacan' but they stopped making it years ago. Now you have to call a guy who has training and the tools in to fix it.
    Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
    -Robert Green Ingersoll
    Sep 2009
    PLATTSBURGH, NY 12901
    The only way is to get down to the source of the leak which is through the copper or aluminum. With no pressure and time to sit there is a no solder leak repair liquid paste that would work. It states that it can hold up to 2500 psi. Almost all supply houses carry it now. Good Luck!!
    Dec 2009
    Bristol NH
    I have pretty good luck with small hard to repair leaks using a product from superseal. A stop leak charged into the system while it is running. Has a leak dye and acid nuetralizer in it too. It's about $$$$ a can but it has saved my company a bundle.
    Quote Originally Posted by boilerman856 View Post
    I have pretty good luck with small hard to repair leaks using a product from superseal. A stop leak charged into the system while it is running. Has a leak dye and acid nuetralizer in it too. It's about Too expensive a can but it has saved my company a bundle.
    So, instead of having the skill and patience required to find and properly repair a leak, you dump a can of glue, dye and some other goo into the system, contaminating it?
    Sounds like a great plan.
    Do you also charge your customers for installing compressor killer?
    Dec 2009
    Bristol NH
    Well jpsmith I see you know everything about my situation. Actually I am responsiblefor almost 100 rtu for my company And many of them in your perfect world should ne replaced due because of age,condition and major components not being available anymore. But in the real world where i live my job is to keep this aging fleet going as long and inexpensively as possible. If i can get another year or two out of it by squirting in some "glue" i am going to do it. That being said do you have anything constructive to say that might help the guy with a coated coil problem?
    I already said my constructive piece.
    As for knowing your situation, I don't HAVE to know your situation, I know refrigeration and I know that stuff is not a good thing to be adding to your systems.
    And as far as being responsible for 100 RTUs......
    Well, I'll see your hundred RTUs and raise you a couple hundred RTUs, a hundred rack systems or so and some other miscellaneous systems, too.
    Find the leak, repair it correctly and move on.
    Leave the glue for the hacks.
    Mar 2010
    Arnold, Mo
    I fold!
    Mar 2010
    not sure if this is a diy job or a service call? but the only way to repair a leak is to get your torch out of your truck/van. it will elliminate alot of thoughts in your noodle, about will this stuff work?
    Sep 2009
    The only way is get your torch out.....
    In a world with ever changing technologies there is never just one way to repair something. The key to properly repairing something is knowing that in the end what you are fixing has your name on it. Can you live with that or do you even care? That's the real question. I personally have never used the paste I mentioned in my last post but I believe as long as it stays on the outside of the system and doesn't introduce any contaminants into the system in the end it is just an epoxy for refrigeration performing the same task as silv.solder and a torch except it can hold up to 2500psi.
    Jan 2001
    So.Cal
    An epoxy that says it can hold 2500psi. Where do they get these crazy numbers. Most copper pipe will burst at 1000psi; maybe we should use epoxy pipe.
    Sep 2009
    I am not sure that is the point of my last post but OK?
