Results 1 to 12 of 12
Thread: possible causes
    Sep 2011
    possible causes
    Web Results For: 2 1/2 ton heat pump, 15 years old, no previous service, not cooling, odb is 95 degrees,in door is 80 degrees,suction pressure is 55 psig, high side is 180 psig,suction temp is 76 degrees, line temp is 96 degrees, the amps are low what is my problem
    Sep 2011
    possible causes
    Jun 2006
    Richmond, VA
    Quote Originally Posted by vatoloco View Post
    No previous service.........
    I wish I had a $1.00 for every response I deleted.....
    "Decidedly Superior in a twisted pathetic way".....
    Sep 2011
    so your saying that it should be running fine there is no problems
    Ontario Canada
    Quote Originally Posted by beshvac View Post
    Check filters, out door condenser dirty.
    Call a pro, get your system serviced. It will save you time and a lot of aggravation in the long run.
    Never give up; Never surrender!
    Sep 2011
    i replace my in door filter also clean my condenser and my acoil
    Frederick, MD
    More than
    the homeowner is able to diagnose or repair. You need to call a service tech.
    GO NAVY, BEAT ARMY!
    A DECADE OF DOMINANCE! +3
    Sep 2011
    possible causes
    thanks for your help
    no need to post same ?? in multiple forums.
    where did these web results come from?
    The problem is...........15 years - no previous service.
    Start there.
    Have it professionally cleaned.
    Problem should become obvious.
    Mount Airy, MD
    Quote Originally Posted by dandyme View Post
    Agreed, Threads merged together
    Carry on
    Jun 2011
    Wake Forest, NC
    Service once a decade is recommended as a minimum, once a year is preferable.
    It's not rocket-science...
    It's electromechanical thermodynamic engineering
