Results 1 to 8 of 8
Thread: subcool
    Aug 2011
    subcool
    is the saturation point on your gages always what every the pressure temp is
    May 2011
    Ripley, WV
    Could you reword the question? I'm not sure what you are asking, not sure if it's because my brain is hurting or what.
    Nov 2010
    N. Idaho
    Quote Originally Posted by Rob_in_WV View Post
    Hahaha, no its not you. I have no idea what this post/question is either
    If I am reading and translating this question correctly, I believe the question that you meant to ask was:
    Is the saturation temperature of the refrigerant always the temperature that corresponds to the equivalent pressure?
    The answer is:
    Unless the refrigerant is an unknown mix or is otherwise contaminated, YES.
    May 2011
    Ripley, WV
    Thats what I was thinking too JP but wasn't sure.
    I should clarify that my above answer is the simple answer.
    It can get a bit more complicated than that when you are dealing with refrigerant blends, but we can talk more about that on the "Pro" side.
    Aug 2011
    The answer is:
    Thank jp that what i was trying to say
    Aug 2011
    Thanks guys
    Thanks guys im not use to putting my though on "paper" for for like of better word
