09-13-2011, 05:22 PM #1
New Guest
- Aug 2011
- 5
Buderus GB 142 vs G234x reliability
I am replacing an oil fired boiler with a natural gas fired unit. I live in southern New England in a 3500 sq ft house with cast iron radiators built in 1922.
I have a contractor selected who did a heat loss estimate. He is well recommended and has successfully installed Buderus units for discerning friends.
I need to choose between the Buderus units listed above. I have an odd chimney which needs to be lined for the G234x. By the time that is included, the units will be within $1000 dollars.
I'd like to go with the GB 142 but wonder a bit about the reliability of the aluminum/high tech unit vs cast iron.
Any thoughts?
Thanks,
Ray
09-14-2011, 10:43 AM #2
I have experience with the gb142 and have found it to be very reliable. The heat exchanger is a cast aluminum and is very easy to remove and clean. When the proper module is installled to allow automatic outdoor rest it is a very efficient boiler that will provide perfect heat throughout the house. I am not familiar with the other model so I cannot comment on that.
It's easier to make money telling the truth... you don't have to remember what you said.
09-15-2011, 05:02 AM #3
New Guest
- Aug 2011
- 5
Sideburns,
Thanks for taking the time to comment. Purchasing a boiler is a big decision made with somewhat limited information. Views of an insider are helpful
Ray
