Results 14 to 16 of 16
Thread: Help with Preway fireplace!
12-05-2009, 08:01 PM #14
- May 2005
- Madison, WI
- 1,078
You need to get a pro out there to look at what you have, and they can suggest what would best suit your needs.
09-26-2010, 08:30 PM #15
New Guest
- Sep 2010
- 1
Is it Preway or the highway?
I have a Preway installed in 1982. I live in Maryland. This week an inspector for a potential buyer found that the outside top of the unit (visible through the upper air vent) has a lot of rust. And now the damper won't open. I assume due to sitting all summer.
The fireplace has worked great even during the past winter. What are my options now? I assume someone can free up the damper but can the outer rust be removed?
I see from this thread that Preway is gone. Is there any manufacture whose unit would fit? How much am I looking at.
A lot of questions, I know. Thanks much.
09-26-2010, 09:42 PM #16
- May 2005
- Madison, WI
- 1,078
I would see if you can get a certified chimney sweep out there to inspect and sign off on the unit and flue. If the damper can be freed up I am not sure why the surface rust would be a problem, but you need a fireplace expert to check it out and not some home inspector.
If the sweep condemns it you might have to sell the house with the fireplace as-is and let the buyer replace it with whatever they want. We have seen this done a lot around here. It does not make sense to replace it for the buyer, what if its not what they want? A lot of people are tearing those old Preways out and putting in Gas units.
