Results 1 to 7 of 7
    Sep 2011
    yearly maintenance
    I recently bought a house and it has 4-5 years old Trane HV90 furnace. Original owner told me that he never got it serviced and it is fine as is. With approaching winter season I wanted to call a Pro to get preventive maintenance performed on the furnace. What should be normally done to a furnace like this?
    Dec 2010
    On a Peninsula in NE NC
    Yes I reccomend you get it serviced and cleaned, unfortunately me telling you what should be done is DIY in my eye's. And I am not saying you are trying to DIY, but someone else may see it and say oh now I know what to do and boom, now they get blown up.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Sep 2011
    I'm not going to mess with it myself, just need high level overview of what needs to be done to make sure that tech will look at everything that needs to be looked up.
    Massachusetts
    Annual maintenance is a "must", especially on high efficiency gas furnaces. Trane particularly has a very tight recuperative coil that needs to be monitored for both efficiency and safety reasons. AC is also neglected frequently. People will brag about how long they've had their systems and never had them serviced but the simple fact is, they've been using way more electricity to operate the system than is necessary due to dirty coils and possible over/under charge of refrigerant.
    If you drove your car until it quit without changing the oil, would you really expect to get the maximum MPG and service life from the auto? I doubt it. Same thing with heating and cooling equipment. Lack of maintenance is where we make all our money. Tee Hee. So don't follow your ignorant prior owner's advice. Be smart an invest in a service agreement for regular, semi-annual visits.
    Southeastern Pa
    You may be able to get info from the Trane distributor if you call with model and serial.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Rochester NY
    Hvac equipment efficiencies are maximums, not guarantees. No matter how carefully you drive that Prius, if the emergency brake is up you ain't getting rated efficiency. Dirt, improper charge, improper gas pressures, poor airflow, these are pulled emergency brakes.
    Hvac maintenance:
    Pay me now, or pay me later and run less efficiently in the meantime.
    Jun 2009
    Nevada
    Speaking of cars, I once had a boss (in a different industry) who had a BMW 5 series company car. This would have been in the '80s. He bragged that he had 60,000 miles on it and had never had it serviced. It ran great, but I wouldn't have taken it if it was given to me. Well, maybe if it was given to me, but I sure wouldn't have trusted it any further than I cared to walk.
