Results 1 to 11 of 11
    Angry Trane Xl13 issues
    i have a 9 year old xl13 trane heat pump, was working fine up until about 3 months ago, started off with honeywell pro 8000 thermostat burning up, then the defrost board fried, traced all wiring and varified correct wiring, replace defrost board under warranty and installed new pro 8000 thermostat, fired it up today and both suction and gas lines on unit are hot and pressures were in the 500 plus range and idea what the heack is going on??
    thanks in advance
    Arizona
    Sounds like it's in heat mode and the indoor blower is not running. R22 system?
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Arizona
    Or someone got carried away when charging it!
    okay forgot to mention that unit compressor is running even when low voltage wiring unhooked
    Arizona
    Quote Originally Posted by graphicelements View Post
    Time to call a pro, sorry.
    well i am a block 2 apprentice, and my journeymen is away on vacation for 2 months, this unit is at my own house, any help at all jim would be apprectiated
    I know what it is from here. Think about it. Pretty easy.
    And turn off the breaker til you figure it out.
    Southeastern Pa
    Ok, apprentice. Answer this question for yourself, don't post it here.
    What component might be having a problem if the compressor can run without a call from the low voltage?
    What other parts must run when the compressor runs?
    That should get you started.
    Others: don't post the answers in this open forum.
    Jun 2011
    OOOOOOO, I know!!!!!!!!
    okay so i changed the contactor however the compressor still runs?? any other ideas?? very much apprecitated guys
    Arizona
    Not unless the contactor is closed, like I said earlier you need to call someone.
