Results 1 to 7 of 7
    Sep 2011
    Filters on Return Grills
    This is in reference to a relatively new home in the south, ~4 years, but I've only lived in it a short time ~6 months. The system has a filter before the blower, no filters on the air intakes around the home but oddly had these felt pad sheets in the exhaust grills, the things the cold air was coming out of just to be absolutely clear. They were slightly discolored but I'll guess they've never been replaced or cleaned in 4 years of constant use so they didn't seem to filter much. The material was relatively dense and I decided to remove some of the pads from rooms that felt warmer even with the vents full open and it seems to have easily increased the air flow by a factor of 2 to 3x. Now I'm wondering if this was a safe or good idea. Since the system does have a filter right before the blower, I assume the cold air coming out is relatively clean and doesn't need filtering, and the pads were just causing excessive air flow restriction but I can't be sure. I've never lived in a home with central AC so I'm not sure if these types of pads would be normal, or recommended, or whoever installed this system was just doing something odd. (There's been other things around the home that I know for a fact aren't quite 'standard' so I wasn't sure on this). Thanks for any advice or input.
    Jul 2002
    Yuma, AZ
    Quote Originally Posted by JSmith76 View Post
    ....The material was relatively dense and I decided to remove some of the pads from rooms that felt warmer even with the vents full open and it seems to have easily increased the air flow by a factor of 2 to 3x. Sounds about right. Now I'm wondering if this was a safe or good idea. It was a good idea for the seller of the product but a bad idea for anyone who uses it. ....so I'm not sure if these types of pads would be normal, or recommended, No and No. ...
    Remove all of them and leave them out.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
    Jun 2008
    NW Florida
    If you remove those filters out of your supply grills. You will notice more airflow, cooler temps and will make your unit last longer. Better idea is a pleated filter on return. The idea of a filter was intended to keep coil clean, not for dust control in house. For any other air filtration I suggest you contact your local A/C contractor. So that filtration does not affect cooling or humidity control.
    Dec 2010
    On a Peninsula in NE NC
    Quote Originally Posted by lynn comstock View Post
    X2
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Jul 2002
    Yuma, AZ
    From Trane air handler specs (page 2)
    Attachment 210472 Note what the equipment manufacturers recommend for protecting their air handlers from dirt.
    INDOOR FAN — Type Centrifugal
    Diameter-Width (In.) 11 X 10
    No. Used 1
    Drive - No. Speeds Direct - Variable
    CFM vs. in. w.g. See Fan Performance Table
    No. Motors — H.P. 1 - 3/4
    Motor Speed R.P.M. Variable ECM
    Volts/Ph/Hz 208-230/1/60
    F.L. Amps 4.2
    FILTER
    Filter Furnished? No
    Type Recommended Throwaway
    No.-Size-Thickness 1 - 22 X 20 - 1 in.
    ... oddly had these felt pad sheets in the exhaust grills, the things the cold air was coming out of just to be absolutely clear. We call them supply grilles. ...
    No big deal though.
    Mark Twain
    Virginia
    them filters in the supply grills are snake oil you need to trap the dirt before it goes though ac
    Rochester NY
    Filters protect your equipment. Cleaner air for you is a secondary benefit. Filters also restrict airflow which is bad for equipment, so you want to filter in the right place, not everyplace. Filter before your equipment, not after.
