Results 1 to 11 of 11
    Aug 2008
    Had TVA Home Experts and Performed a Blower Door Tst
    They said its one of the best homes they've tested in a while. Big thanks, in part, goes to some of the pros here for your help.
    2 problems though
    1) Guy said hot air was invading from the attic from exhaust fan in master BR. He said pop the face and pull "flapper" down. Problem was....the flapper was down..but I did feel the warm air coming in......what do I do.
    2) Some insulation was in a return in my daughter's room (the warmest room in the house)
    Appreciate in comments
    Madison, WI/Cape Coral, FL
    How tight is your home? Blower door test duplicate fresh air infiltration during the average winter day. A healthy home gets an air change in 4-5 hours to purge indoor pollutants and renew oxygen. During warm calm weather, the natural ventilation declines to near nothing.
    Thats when you need a specific amount of mechanical fresh air ventilation.
    You have a clothes drier, bath fans, and kitchen hood that all need make-up air to function.
    After you get the specific amount of fresh air throughout the year, you need to maintain <50%RH to avoid mold and dust mites.
    I suggest you look a ventilating whole house dehumidifier for green grass climates as simple way of get fresh air and keeping the humidity <50%RH when the a/c is not operating. It is always something.
    Regards TB
    Aug 2008
    Quote Originally Posted by teddy bear View Post
    Regards TB
    Very, very tight. Doors and windows are all new and hi tech. Insulation is more than sufficient for mid south.
    I know we do need fresh air but I'd rather not pay more summer/winter on bills to achieve it. Fall and spring, air is too dry
    Quote Originally Posted by AvantGarde View Post
    Without proper fresh air ventilation, your health and your home could suffer some serious consequences.
    Controlling the amount, times and quality if air being brought in is key.
    Tb has great ways of explaining it better than I can.
    Rochester NY
    Very very tight?
    Very well insulated?
    My 10 year old daughter isn't clinically obese, she's big boned.
    ...How much does she weigh?
    I dunno...
    Adjectives are difficult to quantify. We like to see numbers. We need to see them unless you just want "congratulations" as comments.
    It is your choice. The correct amount of fresh air to purge indoor pollutants is not expensive or uncomfortable. Mechanical fresh air is only needed when the home is occupied and the natural ventilation is short.
    Consider that occupants add CO2 and moisture to the air in the home. You can tell how much fresh air a home is passing through the home by monitoring the CO2 levels and/or the moisture levels in the home. If the doors and windows were all open, the CO2 and the moisture levels in the inside/outside air would be the same. The moisture/CO2 levels outisde verses inside change with air change rate change. If we enclosed the home in a plastic bag with occupants in the home, the home CO2 levels would rise very high, becoming life threatingly short of oxygen, and saturated with moisute. With proper air change the CO2 and moisture leaving the home is slightly higher than the air entering the home. If interested in the expected increase, I will continue the post.
    Let me know.
    Regards TB
    Dec 2010
    On a Peninsula in NE NC
    Let me know.
    Regards TB
    I'm interested. or point me to a thread in the pro's side. I actually tried a search last night on ''fresh air'' last night, came up with nothing. Of course I am looking for more detailed measurement and how to, most likely to DIY for this thread.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Apr 2010
    southern california
    Quote Originally Posted by Southern Mech View Post
    Fresh air and proper ventilation has been determined by ASHRAE 62.1
    Arizona
    Quote Originally Posted by acwizard View Post
    For residential its 62.2.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    south louisiana
    OP
    warm air is entering from oversized cut ceiling around vent fan.the cover of fan covers the gap.
    2. Some insulation was in a return in my daughter's room (the warmest room in the house)
    no wonder its warm.. the return is open to the attic thus the insulation inside the r/a
    seriously...don't these utility sponsered audits do more than point out problems?
    no solutions?
    oh yeah...free/low cost audit.
    what were the numbers?
    what size house?
    Tennessee?
    best of luck
    I don't know
    In cold climates the best option for maintaining good iaq in a house is an HRV.
    In warm climates probably an ERV or ventilating dehumidifier.
    economic collapse is a certainty. debt based fiat currency monetary systems can never continue indefinitely because they require continuous creation of new debt to service the existing debt. in the absence of economical growth (which is always predicated on increased resource extraction rather than capital alone), this leads to massive inflation which destroys the currency.
    your leaders can't fix this - they're corrupt and only exist to enrich themselves and their corporate friends.
