    New Jersey
    Please make this job right!!
    ordered a compressor from a trustworthy source and its shorter than the original.
    original is : HRM058T4LP6
    New is : HRM058UU4LP6
    its about 2 " short in height "atleast"
    Pipe sizes are right, and line up.
    I got it raised on 2 x 2 blocks. Before I continue, I need to verify the tonnage is correct before I continue to lock this thing in....
    Cuz I'll send this bch back in heartbeat if it aint right and collect OT on something else here in the plant.
    My wife is already pissed at me ...make it worth my while.
    “If I have seen further than others, it is by standing upon the shoulders of giants.” ~ Sir Isaac Newton
    I'm learning all the time, the tombstone will be my diploma!!!
    Did you ever stop to think, and forget to start again?
    Ohio
    Quote Originally Posted by Tommy1010 View Post
    Step #1 Get in touch with the Manufacturer...NOT the person you
    bought the Compressor from! And find out what the different
    Model Numbers mean.
    I remember running into a Lennox Hot/Cold Deck RTU that had original Compressors with internal Suction Accumulators that ran at 0* Superheat. You could keep your hand on the discharge line!
    The replacement Compressors did not have the Accumulators and required the TEV/Distributors to be replaced to run at 15* Superheat.
    Couldn't keep your hand on the discharge line then!
    Good Luck.
    jogas
    Jogas
    Four wheel therapy, my 1968 Camaro
    Virginia
    The difference is the Application Envelope.
    The T - is optimized for 45/130°f
    and
    The U - is optimized for 45/100°f
    I e-mailed you the .pdf with more info on these compressors.
    Ohio
    Quote Originally Posted by rundawg View Post
    and
    What does UU mean?
    Ask the Manufacturer why they are different heights.
    Jogas
    Virginia
    Quote Originally Posted by jogas View Post
    What does UU mean?
    My guess he had fat fingers and hit the "U" twice. I don't see any listing for a "UU". I'm sure Tommy can clear that up.
    Ohio
    Understood...you're probably right. Didn't think of that.
    I'd still be going to the Compressor Manufacturer's Tech Support for the answer.
    Jogas
