Results 14 to 19 of 19
    Rochester NY
    2 good posts. Jumped to solutions too quickly without understanding lay of land, didn't I...
    How is house heated now? Why are you changing to radiant? Have you had an audit to define deficiencies and assess opportunities, or is this going from your gut?
    Sep 2011
    Not challenging your opinions as I am very ignorant about Hydronic. I have seen European homes used combi tankless water heater to provide hot water and warm house with radiators.
    Different tankless or just homes are smaller?
    Sep 2011
    Quote Originally Posted by tedkidd View Post
    2 good posts.
    An Old flat roofed house, built 100 years ago with 6-8" of crawl space and no heating. We used electric space heaters for bedroom and gas fireplace inserts for living area.
    relocating and putting this old house for rental. House in very high rent area, so lack of heating not a good idea.
    So force air would be difficult due to lack of accessible space. Electric is one way to go but high operating cost? Thought 1/2" water tubes would be doable.
    Just planning at this point.
    Rochester NY
    Tankless water heaters are typically designed with 35-60f incoming water temp and 110-130 outgoing. This is a fairly consistent operating parameter that is NOT the situation a boiler deals with. Boiler may deal with 120f return temp (incoming), for example.
    A wall hung boiler and a tankless water heater are not the same, although they may look the same to most homeowners.
    Apr 2010
    southern california
    Quote Originally Posted by toffee View Post
    Electric space heating is not an approved method of heating in Calif. Heating is required by building codes. Spacepak or a Unico heat pump may work for you, or even Mitsubishi or a Fujitsu mini split system heat pump. A lot more info is needed to steer you in the right direction.
    Rochester NY
    Mini split.
    There I go again...
    Get an energy audit.
