Results 1 to 13 of 18
    Oct 2005
    I just got a two stage furnace installed, the installer hasnt installed a two stage thermostat yet because they were out of stock. He will come back later.
    My question is...Can the old one stage thermostat wires be used for the new two stage thermostat? Or do they have to run new wires?
    they will need one extra wire for proper wiring of a two stage. if you have an extra wire in the bundle, no problem. if not, then yes they will need to run a new wire.
    make sure they actually put up a two stage stat if that is what you paid for. (and i hope you did). they can wire a single stage t-stat, which will control the stages via a timer. although workable, not the way to go for maximum comfort.
    good luck.
    Oct 2005
    I paid for a two stage thermostat, they brought over a single stage one and i caught it before they did the installation. I refused that and they will come back to do the two stage install.
    Florida
    Can't the furnace control the stages? Might not need a 2 stage stat, just depends on wiring. Should get the difference back though......didn't order the nice Visionpro with your new system?
    Yeah, what billva said. Fine for limping along while waiting for the right thermostat to come in, or for the new thermostat wire to be fished, but don't leave it that way permanently.
    Furnace-controlled staging is a travesty. Don't cripple the comfort-producing ability of nice multistage systems with inferior controls because of something so simple as a wire not having enough conductors. The only way to control staging well is to do it based on demand, and only the thermostat knows how much demand is actually present.
    Oct 2005
    Ok guys, I need some help. I got my two stage thermostat installed (Honeywell FocusPro TH5220D), My installer installed it without running new wires.
    I think he just installed it as a one stage thermostat, so i opened it up to see what wires were connected and here is what i found (5wires only). G,W,C,Y,R-Rc were connected. Y2,W2 were left empty. Can anyone shed some light if he connected it correctly to optimize 2 stage function of my thermostat with my 2 stage furnace?
    I seached around the forum and it leads me to believe that there needs to be a wire connected to W2, is this correct?
    If it makes a difference, my furnace is a Carrier Performance93.
    Florida
    That's hooked up like a single stage. Spend the extra $$$ for a Visionpro, not that Focus stat. Right now the furnace is controlling the stages.
    Canada
    2 stage furnace 2 stage T-stat
    I converted myself ran for 3 weeks on single t-stat 2 stage t-stat made a big difference for me. I use setback a lot and with a two stage T-stat the furnace will run in the second stage right away, rather than limping along in the low fire stage for 10-15 min.
    Oct 2005
    Thank for the confirmation.
    So i'm assuming that he has to run new wires in order for it to be correctly installed?
    My parents told me that the installer wanted more $$ for new wires. I mean i paid for 2 stage furnace and 2 stage thermostat. Shouldnt that be included in the price? Am I getting duped?
    Florida
    If you paid for 2 stage stat, and they need to run new wires for 2 stage stat, that's not your fault/problem. That's THEIR problem.....don't pay any extra,or you are getting dupped.
    [Edited by smokin68 on 01-11-2006 at 08:26 PM]
    Canada
    I agree with smokin68, they should have checked the wires...their fault, do not pay an extra cent.
    IMHO
    Lancaster PA
    I thought the 5000 series could use batteries, if so, and you have 5 wires, don't need to pull any more, just don't use common.
    Oct 2005
    Thanks for everyones help. I called the company and told them that the installer installed it as a one stage thermostat and that the installer wanted more $$ for new wires. They are going to talk to the installer. Ill post again to see what they say. Without you guys i would assume everythign was ok and paid fully. A big thanks again!
    Can i ask why the common wire shouldnt be used, just in case they try to use that wire? The manual does say that the common wire is optional if using batteries. I dont see any other wires that he could use from the G,W,C,Y,R-Rc lineup.
