Results 1 to 13 of 20
Thread: Salisbury, NC
09-07-2011, 12:43 PM #1
- Jul 2003
- Central PA
- 105
Salisbury, NC
Looking for an HVAC contractor in Salisbury, NC. I looked at the map but none were close.
Thanks in advance!
09-07-2011, 01:08 PM #2
Professional Member*
- Jun 2011
- Wake Forest, NC
- 352
I know there are a few from Charlotte that check in here. I am in Wake Forest, so that is a bit outside our service area, but hopefully one of the Charlotte folks can help you. Good luck.
It's not rocket-science...
It's electromechanical thermodynamic engineering
09-07-2011, 01:48 PM #3
- Jul 2003
- Central PA
- 105
On a side note I assume it is recommended to have a heat pump installed over just electric heat. This is for a modular home.
09-07-2011, 02:13 PM #4
09-07-2011, 02:46 PM #5
- Jul 2003
- Central PA
- 105
Thanks, any special needs for a heat pump when it comes to modular homes?
09-07-2011, 03:59 PM #6
- Jun 2011
- Wake Forest, NC
- 352
No. Many times the blower and electric heat can be reused. Most modular applications have a drop-in downflow coil that if it is replaced with one designed for a heat pump, and paired up to an oudoor unit will work just fine. Should be fairly straight forward.
09-08-2011, 12:51 PM #7
- Jul 2003
- Central PA
- 105
It appears that way the unit and only return is in a closet on the one end of the structure.
09-08-2011, 01:12 PM #8
What you got going on there?
http://www.youtube.com/watch?v=nFl0n...ture=endscreen
09-08-2011, 01:40 PM #9
- Jul 2003
- Central PA
- 105
Do any work in Salisbury area?
09-12-2011, 10:39 AM #10
- Jul 2003
- Central PA
- 105
Any special equipment/manufacturers needed for this type of application?
09-12-2011, 01:31 PM #11
- Jun 2011
- Wake Forest, NC
- 352
Coleman Evcon series are designed for mobile home applications. Broan also makes the E3EB series air handlers. There are others, but these are the ones I am most familiar with. The Coleman product has its own coils and outdoor heat pump to match with the air handler, and Broan matches with a Nordyne coil and outdoor heat pump unit.
The new heat pump coil can be paired up to your existing air handler (in most cases), allowing you to re-use the electric heat, blower, ect... This lowers the cost. You will need a pro to come out and evaluate the condition of your existing equipment to see if this is a good idea, as age and wear may require a new air handler.
Good luck.It's not rocket-science...
09-12-2011, 02:10 PM #12
- Jun 2009
- Nevada
- 139
Make sure the contractor takes your ducting into account. Very few mobile homes do an adequate job of moving more than about 1200 CFM of air, and you can't skimp on air with a heat pump. You may need to have a more powerful blower installed to overcome the restriction of your ducts. This may lead to more duct leakage as well. It's pretty important to have a contractor that knows manufactured homes. Here in Nevada you actually have to carry a different state license.
09-12-2011, 03:01 PM #13
- Feb 2009
- Portland OR
- 1,549
