Thread: Ranco
    Dec 2010
    New York
    Frown Ranco
    Anyone have problems with caps leaking on newer ranco dual pressure controls
    Feb 2011
    colorado mountians
    This past summer, not one but two brand new out of box caps broke. first lasted over night,then lost walkin charge. second lasted 2 days. then lost charge again. Third times a charm, still running that i know of. Caps breaking where they flare to 1/4" diam (braze joint)
    Dec 2010
    New York
    thanks for reply wanted to make sure it wasnt just the way they were installed
    Ohio
    I once worked at a Shop that would not buy that Brand...only Penn.
    They seemed to hold up better.
    The last Refrigeration Shop I worked at a while ago went to the 1/4" Male Flare Model Penn and used the flexible stainless steel weave reinforced hoses. No more cap tube leaks.
    Makes sense when you factor in Labor and Refrigerant cost...especially on a Rack System.
    Jogas
    Four wheel therapy, my 1968 Camaro is gone and will be missed
    danfoss makes a nice one with very thick copper. I've yet to use one but seen it at the supply house.
