Results 1 to 13 of 33
    Sep 2011
    Ontario, Canada
    Fujitsu mini split wiring
    I am installing a mini split and the wiring has me a little confused, it's showing that I am to run 3, 230v wires from the outdoor unit to the indoor unit. Usually on other models this wire would be low-voltage. Any input would be greatly appreciated, Thanks
    Southeastern Pa
    Quote Originally Posted by affordablehvac View Post
    On all the minis I see, there is HV wiring between the units.
    If you are a pro, get your post count up to 15 and apply for pro membership. We don't hash out questions like this in an open forum.
    Sep 2011
    Ontario, Canada
    this one shows 3 wires all 230v plus the ground, is this correct?
    Arizona
    Some models use 36 volts, the model you have apparently is a model that uses 230 volts ( that is how most are).
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Sep 2011
    Ontario, Canada
    There is a 3rd 230v wire that is labeled "control", as well as the ground wire, so to wire up this unit properly i need 12/3 ?
    Nov 2010
    you will need 14/3 wires. fujitsu uses high voltage control wires for communication on 3rd
    wire.1st and 2nd is to power the indoor unit.
    801 Del Rio pike Franklin Tennessee
    Are you talking about Inverter type unit?
    mesa arizona
    Frown hey
    hey bud ur hi voltage is ur control voltage budddy read the schematics
    Dec 2003
    Citrus County, Florida
    you should not be posting the same question on 3 different sections. go to the Fujistu website site and retake the lessons. your answer is there.
    Doug
    Sep 2011
    Ontario, Canada
    thanks, but im waiting for the dealer approval to access the training off the website... so im coming to this site for the answer.
    we do not give information to those that may injure themselves or others.
    if you are a professional then you know how to get that information.
    Sep 2011
    Ontario, Canada
    I am a professional, i just haven't installed a fujitsu before, only LG which requires low voltage wiring between the indoor and outdoor unit. I was just simply looking for confirmation from someone who had installed one before. This is my first time on this site, so if im in the wrong section please let me know.
    Arizona
    The answer is LG ( on there smaller tonnages) uses 36 volts ( as I said on one of your other posts), Fujitsu uses 230 volt. If your a Pro this is simple, sorry!
