Results 1 to 13 of 30
Thread: trane rtu induce fan mtr.
09-04-2011, 11:14 AM #1
New Guest
- Apr 2011
- 3
i have a fan mtr, that wont ever shut off
09-04-2011, 11:28 AM #2
Trane has had some issues with combustion motors on some units.
09-04-2011, 11:28 AM #3
Hi Dave,
The motor is bad, it has shorted internally winding to winding causing it to run continuously.
You must replace the motor.
Do you have a local contractor to call for this service?
Good Luck,
AllenUA Local 602
A man who says that he can't learn anything in a class is exactly right.
09-04-2011, 11:39 AM #4
Might want to actually diagnose the motor and power circuit before replacing any parts..
We dont even know what model unit he has, it was just a guess that it was a Voyager.
09-04-2011, 06:37 PM #5
New Guest
- Apr 2011
- 3
model ysc036airm12d propane fuel i replaced motor. all safeties120 v0lt and closed control supplies 120 volt to both leads to motor. only way i could get motor to stp would be to disconnect 1 power lead to motor any ideas?
09-04-2011, 08:54 PM #6
Yes.
Get a good commercial tech out to look at it.
Trane did have some service bulletins on combustion motors and associated parts.[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
09-05-2011, 09:26 PM #7
- Jul 2011
- Canton,Ma
- 7
Allens right the motor is shorted internally winding to winding, i've seen this at least 5 times. use an ohm meter to check windings you'll see whats going on, the assembly for this is around ********** thats the discounted price if you have an account. you can always let it go until it fails....trane always has these motor assemblies in stock. good luck
Pricing not allowed, please.
Mod
09-05-2011, 09:30 PM #8
- Jul 2011
- Canton,Ma
- 7
forgot to mention check the ignition board there should be a rly that sends the other leg of power to the inducer motor make sure its stuck shut
09-05-2011, 09:36 PM #9
09-05-2011, 09:39 PM #10
- Jul 2011
- Canton,Ma
- 7
you unplug it during the summer
09-05-2011, 09:43 PM #11
09-05-2011, 10:01 PM #12
You should refrain from giving unprofessional advice like this.
The OP needs to have the unit repaired correctly and not have to plug and unplug a motor seasonally.
There are a couple of different things that could cause the problem and it requires a professional to diagnose it.
You should work on getting your post count up and apply for Professional Membership.
09-06-2011, 08:24 AM #13[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
AOP Forum Rules:
