    I have Aprilaire 700 Humidifier installed on Bryant 355MAV042080 furnace controlled via Evolution Control.
    Humidifier runs whenever the fan is on. I normally run fan for continuous circulation. Is there the way wiring it so the humidifier will only go on when both the fan and the heat are on?
    Any help would be greatly appreciated.
    Mark
    Nov 2000
    Yes, you need to go into the advanced settings and tell it "No" to the "Run with fan" setting under the humidifier setup.
    Yes,
    That was a fix. I discovered that solution soon after posting.
    Thanks, anyway!
