Results 27 to 39 of 57
  1. #27
    Jul 2010
    Yes I do, but I'm driving so I am going to have to do this after bit
  3. #29
    Quote Originally Posted by 02powerstroke View Post
    Drop the phone and hold onto the wheel!
    Catch you later if I can.
  4. #30
    Jul 2010
    greater subcooling means that you you are below the saturation temp by so many degrees... waht this means is that the refrigerant can absorb more energy before it starts to evaporate... If you have more refrigerant, more subcooling and the same load, you will have less refrigerant turning to a vapor (vaporization) so your vapor pressure will be lower on the suction side of teh compressor... all it means is that you are getting more cooling out of your refrigerant...
    Am I missing something without going into enthalpys?
  5. #31
    Dec 2010
    On a Peninsula in NE NC
    ? hmmmm?? design pressures on manufacture label?/? = test pressure, not operating design.
    now if we are talking design pressures for operating temps and pressures and they are that high, you have the wrong refrigerant.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
  6. #32
    You're overthinking.
    In simple terms, if you measure subcooling, what do you know?
  7. #33
    Jul 2010
    Your refrigerant is a liquid
  8. #34
    May 2009
    Jacksonville FL
    It gives you an idea of how much liquid is in the condenser coil. If you had a restriction in the evap area, you might accumulate more refrigerant on the condenser
  9. #35
    Jul 2010
    Quote Originally Posted by ChaseAir View Post
    thank you... that makes sense
  10. #36
    Jul 2010
    ok... I went back and tested it one more time.. here is what I ended up with
    Suction Line Temperature ~ 60F
    Suction Pressure - 83 PSI
    Liquid Line Temp - 96F
    Discharge Pressure 202psi
    Refrigerant - R22
    THe model of the condensing unit is a 38CKC042
  11. #37
    May 2009
    Jacksonville FL
    11 superheat. 6 subcool. It would help to know indoor wb db and delta t.
    You have low subcool for sure. If it is a txv metering device, it is most likely undercharged. If it is a piston, you either have low airflow or too big of a piston.
  12. #38
    Jul 2010
    Indoor temp is 78F, will have to measure wet bulb. The consensing unit is a piston unit. This is an original split on a ranch that had the basement finished recently.
  13. #39
    Exactly.
    And what part of the system needs liquid to operate correctly?
