Results 1 to 2 of 2
    Apr 2006
    Columbus, Ohio
    peerless pizza oven
    model number - cw61ns
    I haven't worked on much of these, and i just want to make sure that i am picking the right part that is bad. The pilot will light and stay lit. The on off handle allows gas to flow normally. I have gas coming out of the saftey valve and going into the temperature control valve. No matter what i turn the knob to on the thermostat valve it will not light. I have no gas coming out of this valve. So i feel that something is wrong with this valve. I am wondering what all checks i can do to make sure this is bad. Also on the peerless website they have a part that they call the thermostat. Is that this valve?
    Thank You
    J. King
    Lake Worth, FL
    It sounds like you did all the right checks. And yes, that part is called the thermostat.
