    Aug 2005
    I have a carrier weather maker 8000, model # 58wav. The probelm I am having is intermitant. The blower is on with the burner not lit. The error code I am getting is 14. If I power off and power backup the error clears and the furnace works fine for a while and then the same thing happens. It is always error code 14. Any help anyone could give me would be appreciated.
    SE Michigan
    Look on the the inside cover of the blower panel or in your owners manual to determine what the code means.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Florida
    Is your filter clean? Look in the tech manual that came with the unit.
    Apr 2003
    Welcome to HVAC TALK.
    Here's something to think about...
    When was the last time you had your unit cleaned and inspected?
    Now you have a problem with the unit. Fuel costs are skyrocketing.
    So why not call in a professional to repair the unit? While they are there they can clean and inspect your unit to insure a safe living environment for you and your loved ones. Not to mention, having an efficient running system could save you more than the cost of the service.
    What's your safety worth? I'm guessing more than the repair bill.
    Thanks for your understanding.
    (we can't help DIY, due to site rules )
