Results 14 to 23 of 23
Thread: Coil Cleaning
    Dec 2011
    Farmingdale, NY
    high gpm's
    Dec 2011
    Farmingdale, NY
    steam doesn't penetrate the coil you need to use high volume of water to dislodge the dirt from the middle of the coil
    Henrico,VA
    Interesting topic
    I am still looking for the best way to clean the horizontal
    coils that some split systems incorporate.
    I always feel like I missed a lot of dirt when trying to clean from the air entering side.The water seems to build/load up between the fins and makes cleaning that much more difficult.
    A.B.C.-always be careful!
    Oct 2010
    Utah
    There are some older units with double coils that the only way to clean it is to pull the top and separate the coils or it all just ends up stuck between the two even if you clean from both sides.
    Dec 2011
    I get good results when I 1st give it a quick wash with water to blow surface dirt away and then apply coil cleaner.
    I think that low pressure washing from the inside out gets best results. If you start pressure washing from outside in, I’m afraid that all your doing is pushing (or forcing) the surface dirt all the way through the coil, making it a bigger job then what it was
    Nov 2011
    Georgia
    Cleaning coils is not as simple as it sounds. A lot of variables to conceder, as you can see reading through this discussion. I didn’t see where anyone mentioned the roof. If you’re using the harsh chemicals please make sure you flush the roof before the chemicals stain or worse, compromise the roof membrane. No one needs an owner to spend thousands of dollars on roof leaks and finding out it’s something you created.
    Always leave it better than you found it.
    Tulsa, OK
    Carrier's "Novation" type coils can only be cleaned with WATER ONLY.
    I wonder about that technology especially when used as a stacked split coil situation. Just imagine how many helper techs are going to "kill" condenser coils now.
    Jan 2002
    Hamburg, Pa.
    Quote Originally Posted by acdave17 View Post
    Be especially aware on steel roofs as coil cleaner discolors it. I've seen a red roof turn black where the cleaner contacted it.
    Jun 2013
    Central Florida
    Quote Originally Posted by darkbeekeeper View Post
    I use a steam cleaner it works well on most rtus but it is not the answer for all units. i brush them off use the water hose then hit with steam. with steam i dont have to use chem and i have more pressure without the fins bending. I was cleaning indoor coils with cans of cleaner and after about the tenth one the cook had asma attack i went to a steam cleaner after that the best 3 grand i ever spent its paid for its self in time, chem and easy of use i love it
    What brand and model of steam cleaner? Looking for one!
    JUST A LITTLE CLOSER AND THE LITTER BOX IS ALL MINE!
    Jul 2002
    Yuma, AZ
    I made a cleaning wand by taking a male water hose fitting and brazing a 2 foot length of 1/4" tubing onto it. Bend the tip about 1/2" to a 60 to 90 degree angle. It reaches into tight spaces and corners and delivers a narrow but strong stream of water. A little experimenting will give you good results. No harsh cleaning chemicals needed if the dirt is not greasy.
    TIP: Ever clean lint out of a spine fin coil? A large soft flame will turn the lint into ashes and then it washes out easily.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
