Thread: Burners
    When the burners ignite, the burner flame is normal until the blower starts. At this time, continuous roll out occurs. What is the problem???? And what it continuous roll out???
    SE Michigan
    A cracked heat exchanger and carbon monoxide come to mind.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    Thank You!!!!
    Nov 2005
    donegal pa
    sure sounds like a cracked heat exchanger to me to.
    i agreewith coolwhip 100%
    Apr 2003
    Yep, it's time to call a competent professional to diagnose the problem and either make the required adjustments or get a quote for a new heat exchanger/furnace.
    Jan 2002
    Ft.Worth,Tx
    Thumbs down Dangerous-Turn off
    This is not good , I would suggest that you turn your unit off and get electric heaters until you have your unit checked by service company..
