Results 1 to 13 of 14
    Nov 2010
    Montreal, Quebec.
    HP coil in return duct
    I am having a gas furnace and heat pump installed. This is a northern climate house so the furnace is in the basement with a plenum and trunks. The old furnace had the HP coil above the furnace in the plenum. One installer is talking about putting the coil in the return duct, he says it's more efficient that way. What do the Pro's think.
    Portland OR
    Quote Originally Posted by Norm01 View Post
    Is he installing an air handler? It has been common practice that an Air Handler pulls air across the coil while a gas furnace blows air across the coil. However even the new Trane air handlers are now pushing air across instead of pulling across air. Without knowing what system you are having installed this does not meet my equipment specs.
    Check out my YouTube channel - http://www.youtube.com/user/skyheating1 We have customer testimonials, product reviews and more!
    Like us on FACEBOOK if you like our advice here!
    Nov 2010
    Montreal, Quebec.
    Installing gas furnace with blower, return comes in the side of the furnace and plenum on top.
    May 2011
    Ripley, WV
    Sky, I've always been told that if you pull through the coil and then across the heat exchanger it can cause condensation on the HE and possibly lead to premature failure. Would you agree or disagree?
    Portland OR
    Quote Originally Posted by Rob_in_WV View Post
    Exactly, I realized I didn't specify the reason why I disagreed with the installation so thanks for helping me out lol.
    I think the installer is just used to doing air handlers and not gas furnaces, but I would not allow that installation in my house or any house that I work on. In fact in my years I have not even seen a gas furnace installed this way. Is it to late to find another contractor to perform the work?
    Nov 2010
    Montreal, Quebec.
    Not too late and he will do it the way it was however he did not recommend it. Thanks for the reply's.
    Frederick, MD
    I would
    be willing to bet if they read the installation manual, they dis-approve of putting the evaporator coil before the heat exchanger. There was some talk about it being OK if the heat exchanger were aluminu or stainless steel, but I still would advise against it.You will be better off with the coil on top of the furnace and using the proper controls. JMHO
    Jun 2010
    Philadelphia PA
    Rob is right
    WHAT HE SAID!!!!!!!!!!!!!
    DON'T LET HIM DO IT
    May 2011
    Ripley, WV
    Quote Originally Posted by SkyHeating View Post
    No prob. I was hoping I wasn't stepping on your toes by bringing it up.
    Cincinnati, Oh
    You shouldn't put a coil before a heat exchanger.
    "Just get it done son."
    Dad adjusted
    I would not let anyone install anything if they first suggested the coil in front of a heat ex-changer. I can only imagine what other screwy ideas they might come up with, or corners they might cut.
    Feb 2011
    North East Ohio
    I agree with that. It makes perfect sense
    Thumbs down
    International Fuel Gas Code 627.8
