Results 1 to 13 of 14
Thread: Plenum question
    Jan 2001
    Plenum question
    Would ducts at the end of a plenum (on sides) have a tendency to pull more air? because they are at the end?
    Feb 2011
    North East Ohio
    Yes. Path of least resistance. Are we talking about a plenum or a trunk (rectangular) duct? Balancing will take care of this problem
    Jan 2001
    no just a plenum with traditional round metal ducts attached.
    I assume that the premium way to distribute the air would be a sophisticated trunk system, or is this over kill for a residential system?
    Feb 2011
    North East Ohio
    Quote Originally Posted by stardotstar View Post
    Maybe we are talking about 2 different things. A plenum to me is the square duct rising up from the furnace/AH. The duct that runs horizontally acroos the basement or attic is what I call the trunk.
    Jan 2001
    Probably my bad, talking about the supply side after the furnace where the air is distributed to duct lines?
    Cincinnati, Oh
    You have an extremely basic form of a distribution system.
    You have a box on top of the furnace, and a bunch of round pipes attach to it, yes?
    That works well for certain applications.
    In a traditional residential home, you would find the box on top of the furnace (the plenum). Then square, 8 x whatever ductwork. Then from that square duct work, comes the round pipe.
    This is a good duct setup.
    "Just get it done son."
    Dad adjusted
    Jan 2001
    Horizontal system in attic, yes.
    Cincinnati, Oh
    How big is attic space?
    Dad adjusted
    Jun 2010
    Philadelphia PA
    The take offs near the end will have better airflow
    If the extended duct (same size) doesn't leak then the airflow will be better because as the air is removed, the velocity in the trunk is reduced and the air has an easier time making that 90 degree turn at the take off.
    look at the take off fitting values close to the begining and after the 2nd, 3rd of more hits with no size change
    Jan 2001
    Quote Originally Posted by hvacvegas View Post
    about 1700 square feet<
    Cincinnati, Oh
    Sounds like long flex runs.
    Dad adjusted
    Jan 2001
    The current duct work is metal and the longest run to the back bedroom with the lowest volume is about 30 feet.
    Jun 2010
    Philadelphia PA
    star dot star
    Is that the old CPM86 *.* reference?
