Results 1 to 13 of 18
Thread: 75k or 90k?
    Aug 2011
    75k or 90k?
    Got a couple of guys who are recommending the following.
    - Lennox 95%, 88k BTU
    - Bryant 95%, 80k BTU
    I'm wanted to pick up a Rheem furnace as I like the pricing where I'm looking, however the 95% efficient ones only come in 75k and 90k BTU. Any thoughts on which would be the better to go with?
    chicago suburbs
    get the right size
    how would we know what size you need?..what size should i get for my house?..what about my neighbor?... his house is nice.
    FILL OUT YOUR PROFILE!!
    Apr 2004
    MN
    Have a load calc performed and get the size that will meet the requirements of your house. Thats the best we can do for you.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Aug 2011
    Sorry if I was not clear enough. The home is a very unique. In total it's about 3600sq ft, with the front and back portions of the home being heated by seperate furnaces. The front portion of the home comes in around 2000sq ft and the load calc is giving a recommendation of 82k. I wanted to go with Rheem however the models stradle the 80k range with only a 75k unit and a 90k.
    Figure I def don't want to overcompensate and feel the 75k would be the way to go.
    Apr 2004
    MN
    If the load calc was performed properly, it won't lie. Have your contractors quote you a 2 stage furnace.
    Portland OR
    Where do you live to get a 82K BTU heat load on only half the house? I have a feeling those numbers are doctored more than a little bit. I would probably go with the 75K BTU furnace but MAKE SURE THE AIRFLOW MATCHES. People to often size their furnace on their heating load and forget that furnaces have a 3 ton, 4 ton or 5 ton blower and that needs to be sufficient and match up with the air conditioner/heat pump if you have one.
    Check out my YouTube channel - http://www.youtube.com/user/skyheating1 We have customer testimonials, product reviews and more!
    Like us on FACEBOOK if you like our advice here!
    Aug 2011
    We live in Minneapolis, so as you could imagine, butt cold. Interestingly enough, the current furnace we'd be replacing is a 31 year old Lennox. Input on that is 3ton & 82,000 and I'm guessing 60% efficiency. From my math that's about 50k output. So I find it interesting that I've been quoted with an 82k and a 88k @ 95% efficiency.
    Portland OR
    Quote Originally Posted by numb3r View Post
    Me too... if I were to guess and take a shot in the dark I would say you would be fine with a 75K BTU. But this is without any additional knowledge and is a pure guess. Get another quote or use the HVAC-Talk.com contractor locator map.
    Aug 2011
    Ok, I'll do a bit more snooping and see what I come up with. Will let you know.
    Chances are you are over sizing. But we really don't know. There is only one way to be sure. Have a load calculation done.
    Problem is that many contractors will over size anyway because you're in a cold climate, just to cover their arse.
    Aug 2011
    Correct me if I'm wrong, but going off the size of the current 30 year old furnace (output of around 50k) - if I purchase this Rheem 75kb multistage, I may find out that it would run at low fire the majority of the time. Would you rather have a multistage running at low fire compared to high most of the time?
    chicago suburbs
    ur done.
    Aug 2011
    And you've been super helpful Tinner. Thank you so much.
