Results 14 to 19 of 19
    Not hsi
    the status light, of course..
    continuous rapid blinking
    htg guy,
    maybe they can help you with you with the spelling of isn't. oh..looks like I just saved you the trip
    sorry, you are right. that was a rude comment.
    if you had been in the french army, you would have called for help along time ago.
    obviously your electronics background is not enough to troubleshoot your furnace, or you would not be here.
    good luck. and thank you for your service to our country.
    Feb 2002
    Originally posted by piccolo
    btw..robotec
    I was an electronic tech in the military for years and know my way around a schematic. By passing the limit switch as a pratical test is not inherently risky.
    You already proved that you have no clue by pulling a wire from the limit. If you are serious, you need to call somebody that knows what they are doing. I hope you didn't just change the sensor because that cured your problem a few years ago. If that is the case, about 12 more parts and you should be back in business.
    [Edited by htg guy on 12-05-2005 at 07:13 PM]
    Nov 2000
    Eastern PA
    RoBoTech..if brand bashers give the industry a bad name, how about elitist service techs.
    I may be wrong here. This troll does recognize my elitist nature.
    So can anyone give me a little guidance and a little less sh**?
    Probably not. Ya know; there is also a New Jersey clown on another site that posts like this. Bageltech....is that you?
    Government is a disease...
    Ecclesiastes 10:2 NIV
    s.e. ohio
    Whenever i come across a blinking hsi i replace the furnace. Works every time!!!
    Steve J.
