Results 1 to 13 of 19
    Replaced a bad flame sensor but now my hsi is continuously blinking. The thermostat does not prompt any activity from the furnace unless I pull one of the leads froom the limit switch. Then the internall blower comes on immediatly but no gas, spark or flame. However at that point the hsi gives me the 4 blinks to indicate limit switch problem...Hmmmm
    Nov 2000
    Eastern PA
    If this is not a joke, definitely call someone that knows what they are doing and at least knows the terminlogy of the product.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    leland nc
    not enough info
    i can say sounds like you have done all you can do
    time to call a pro and have the unit fixed and service
    why did you replace the flame sensor?
    Not a joke. Have fixed this and others many times but am stumped by this one. Replaced the flame sensor because unit was lighting for 30 seconds or so then cutting off..trying again doing same. I replaced the sensor two years ago succesfuly and problem was fixed this time, no luck.
    if the hsi is blinking, then replace it too.
    Nov 2000
    Eastern PA
    You need professional help.
    btw..robotec
    I was an electronic tech in the military for years and know my way around a schematic. By passing the limit switch as a pratical test is not inherently risky.
    Memphis
    It almost sounds like you were expecting it to start sparking & the gas to come on & light the flame when you pulled the wire off of the limit switch.
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
    what, the French army?
    Nov 2000
    Eastern PA
    This has gotta be eddy again. Geez, don't you ever get bored with being boring?
    Ok..
    Firstly..
    If a switch of any kind is stuck, bypassing that switch (temporarily) for the purpose of checking the status of the rest of the system is not out of left field and in this case the suggestion of another HVAC "tech".
    Secondly..
    RoBoTech..if brand bashers give the industry a bad name, how about elitist service techs.
    and lastly,
    Bilva..I can tell you never served a day in your life to be so rude about the issue. The French wouldn't have you!
    So can anyone give me a little guidance and a little less sh**?
    Feb 2002
    Wink
    Replaced a bad flame sensor but now my hsi is continuously blinking. Hmmmm
    I can honestly say that a "constantly blinking HSI" is something I've never come across.
    My thinking is that you need to go elsewhere so you can be with people that can help.
    [Edited by htg guy on 12-05-2005 at 07:02 PM]
