Results 1 to 7 of 7
    Midwest
    Most efficient saw for cutting Freon cans
    I have a bunch of old, empty, disposable, 30# refrigerant cans I'd like to cut in half. Just wondering what the most efficient (fastest) saw (not torch) would be for doing this. I've tried various power saws before, but it was a pretty slow process.
    Jul 2009
    Connectitaxed
    I would use a grinder with a cut-off disk. Just curious...why do you want to cut them in half?
    Cal
    Grinder with a cutting blade would be my first choice
    newton,mass.
    Quote Originally Posted by midhvac View Post
    Depends which direction are you cutting them?
    I agree with the other guys about the grinder, a good saws all and blade would do OK as well.
    Hmm I was just thinking (yes thinking) being those cans are round you may want to hold them between your legs to cut them so wear old work trousers
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
    Skokie , IL near chicago
    sears.......
    ....sells a small metal cutting saw with counter rotating blades that is great . I've seen electricians using them to chop conduit instantly , they're on sale once in a while....check it out.....Jack
    B[COLOR=a friend is one who knows us , but loves us anyway
    Grottoes VA
    Plasma cutter. This weighs 18lbs.
    Denver, CO
    I would use a band saw and clamp the drum between some plywood.
