Results 1 to 13 of 15
    Apr 2011
    North Florida
    Running two 2" PVC pipes thru one 8" existing roof opening . Whats the best way ???
    I have an existing 8" roof opening which the previous 65% gas furnace
    and water heater was vented thru . The last owner abandoned both and
    went with electric furnace and electric water heater...and simply
    placed an 8" sheetmetal cap over the roof opening .
    I want to install a 95% gas furnace requiring two 2" dia. PVC Pipes
    (intake and exhaust) and would like to utilize the present 8"roof
    opening . I could cut two seperate holes thru the existing cap ,
    or, is it better to use one rubber roof jack for both pipes to go
    thru if such a thing is offered ? I want to have it sealed good
    against the elements.
    Your help is appreciated
    Jul 2010
    georgia
    Quote Originally Posted by JustCallMeDave View Post
    I want to install a 95% gas furnace requiring two 2" dia. PVC Pipes (intake and exhaust) and would like to utilize the present 8"roof opening . I could cut two seperate holes thru the existing cap , or, is it better to use one rubber roof jack for both pipes to go thru if such a thing is offered ? I want to have it sealed good against the elements.
    You'd probably want to get a concentric vent kit.
    Apr 2011
    North Florida
    Quote Originally Posted by b26440510 View Post
    So a kit where you have a pipe within a pipe to handle exhaust and intake ? The entire kit is then put thru the roof opening then sealed , i take it ??? Ill do a google to see what that looks like. Thanks.
    Keokuk, IA
    You might want to run the cocentric offset in the existing pipe and not centered incase you want to get a direct vent gas hot water heater in the future.
    Apr 2011
    North Florida
    That would be a valid concern, except, I made myself a Solar Hot Water Collector which is giving me some mighty hot water of 145-160 f. ... enough for a daily shower and dishwasher , so I dont use my water heater anymore -- living in FLorida has its advantages :
    (http://rimstar.org/renewnrg/diy_pex_...thermal_dn.htm ) .
    Jul 2010
    georgia
    Yeah, basically turns the two pipes into one. They are make/model specific so check which ones are compatible with your equipment.
    Jun 2009
    Albuquerque NM
    Or get an Alumi-flash pipe portal. You can run four 1" to 2" pipes through it, but nothing really hot (i.e. nothing requiring a metal vent). The base is aluminum and it has a EPDM cap. They have one with a single 2" to 6" cap too, if you want to run the concentric vent through it.
    Apr 2011
    North Florida
    Ill google the alumiflash pipe portal to see what is looks like . Thanks
    Cincinnati, Oh
    I think I would replace the shingles/decking in the area, and put a new flashing at another spot.
    "Just get it done son."
    Dad adjusted
    Jun 2009
    Albuquerque NM
    Manufacturer is Commercial Products Group:
    http://www.commercialproductsgroup.c...lumiflash.aspx
    Or check the Big Rock Supply web site.
    Apr 2011
    North Florida
    Quote Originally Posted by garya505 View Post
    Great. Thanks.
    Jul 2010
    georgia
    wow, those seem to be more for industrial. Would anyone need 4/5 vents in one location for a house?
    Looks like maybe the portal line would be a bit more practical.
    Keokuk, IA
    Sure, 2 gas DV fireplaces, DV hot water heater, 2 furnaces. Not a bad idea to have just a single roof penetration. The fewer holes you can put in a roof the better.
