Depends upon your controls. Many these days are using the Vision Pro thermostat as the dual fuel control. It will control a 2 stage heat pump but only 1 stage for backup so in gas heat mode, you'll have to use the timer to time 2nd stage on, a comfort disadvantage. I'm not sure if there is anything out there that could handle all 4 stages. Maybe the Infinity/Evolution could. calling dash
