    Aug 2011
    Chimney Selection
    Hello,
    I'm getting a new wood burning fireplace installed, and I'm looking for feedback on chimney selection. I apologize if this discussion has already occurred on this site, however, I couldn't find one.
    My two options, available through the fireplace shop I'm working with, are:
    1. Duravent with a galvanized outerwall and stainless steel inner wall
    or
    2. ICC stainless steel outer and inner wall
    Its my understanding that the ICC is held up as 1 of the industries best, however, its also more expensive. Any comments, thoughts, opinions are welcomed.
    Sorry if I'm short on details, but I'm a novice. I can provide more info. if needed.
    Thanks!!!!
    Aug 2011
    Also,
    Any opinions on rooftop dampers?
    Thanks!!
    S.E. Pa
    Question
    What type of fireplace is this? Masonry of factory built?
    Aug 2011
    Factory Built
    S.E. Pa
    Cool
    The chimney listed for use with a specific model fireplace is expressed in the listed instructions. If both of these chimneys are listed for use with this fireplace including the anchor plate and how to install then they are both ok. However, note that chimney with a galvanized exterior shell is intended for use inside the house then transition to stainless for the exposed portion. Duratech has the same interchangeable chimney available with both outer casings.
    What make and model fireplace?
    HTH,
