Thread: Advice
    Aug 2011
    Advice
    I'm a contractor and have a house that has a bedroom that has a trunk line running through it that is not insulated. They close the vent in the room when it is cold but it does not help at all and they say its freezing down there. What is the best way to insulate this trunk line to keep the room from being so cold. Will enclosing it in 5/8 drywall do the job or is there a special wrap or insulation for this?
    Jun 2011
    Hammond,La.
    You can use a foil duct wrap for round duct. I would use duct board for square. Closing it in with drywall won't hurt after. It needs to be insulated to keep from condensating.
    Aug 2011
    Where do I find duct board? Is it a rigid foam?
    what do you mean by trunk? are there duct's further down the line that come off of this duct after it leaves that room that is freezing? or is this duct just for that room only?
    if you're going to enclose it with dry wall, i would just wrap it with R8 duct wrap.
    Jun 2011
    Hammond,La.
    It's a rigid fiberglass board insulation with a foil backing. Easy to cut and work with, light and can be painted if you don't want to frame in and drywall. Any AC supply house should have it.http://www.certainteed.com/products/...n/index/317382
