Results 1 to 10 of 10
    Don't use Bleach
    Home owners, don't use bleach to keep your condensate drain clear, and techs, stop recommending it.
    Here's a quote from the Rheem/Ruud _HSL air handler installation instructions
    "12.2 INDOOR COIL - DRAIN PAN - DRAIN LINE
    Inspect the indoor coil once each year for cleanliness and clean as necessary. In some cases, it may be necessary to remove the filter and check the return side of the coil with a mirror and flashlight.
    IMPORTANT: Do not use caustic household drain cleaners, such as bleach, in the condensate pan or near the indoor coil. Drain cleaners will quickly damage the indoor coil."
    N.E. Iowa
    That's a good point Rick and that's also why it isn't wise to install a furnace or air handler in a laundry area where there will be a lot of chlorine being used. The same applies for a swimming pool pump/filter room where chlorine might be stored.
    Not only is chlorine highly corrosive to evaporator coils, but it will also destroy a heat exchanger in short order because the high heat accelerates the process.
    ______________________________________________
    Sign petition to limit Congressional and Senatorial terms. http://www.termlimits.org/
    "We may have all come on different ships, but we're in the same boat now."--Martin Luther King Jr.
    Frederick, MD
    We use
    bleach all the time, but only in the trap and condensate drain itself. never directly in the pan.
    directly in trap or condensate pump will not cause any problems, it should not be sprayed on coil it will etch the aluminum
    Jun 2011
    Hammond,La.
    Assuming the condensate drain is constructed correctly with no traps in the line and there is a P trap installed then bleach could be used following a good dose of water to rinse. If the line is not removed an the bleach is simply poured in a clean out that is close to the AH then overflow will backwash into the pan and will sit in the P trap.
    Chlorine vapors can cause the same corrosive effects as the liquid on these coils just to a lesser extent over time rather than an almost instant oxidation from the liquid. Poorly drained condensate lines without P traps will hold the chlorine and allow the vapors to return to the coil.
    Really boils down to end user competence.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Mar 2011
    VIRGINIA
    You can use it in your condensate pump and/or EZ trap or the other trap, never inside of coil box.
    Cincinnati, Oh
    Quote Originally Posted by Rcb2875 View Post
    Which is why I tell customers to never use bleach. Hit it with an easy trap brush (comes with the easy trap) when you change the filters. We'll take care of the rest.
    "Just get it done son."
    Dad adjusted
    Jul 2011
    My installer told me to use white vinegar, not bleach.
    Cincinnati, Oh
    Quote Originally Posted by Clocker View Post
    I wouldn't use any substance.
    There's plenty of "natural" chemicals that eat copper.
    There was a post in the wall of shame awhile back, where a cook was keeping a 5 gallon bucket of tomato paste open. The return sucking in the tomato paste was killing evap coils.
    Dad adjusted
    I'll stick with the manufacturer's recommendations....
    "Do not use caustic household drain cleaners, such as bleach, in the condensate pan or near the indoor coil. Drain cleaners will quickly damage the indoor coil."
    I think the manufacturers know. I have lots of stories about bleach. My customers know bleach will void manufacturers and labor warranties.
