Results 14 to 16 of 16
Thread: Freon Leak??
    Cincinnati, Oh
    Quote Originally Posted by bryantman21 View Post
    anymore condensors are never bare copper but usually galvanized or coated with something. Being that it is only 5 years old what does the condensor look like? If he knows the condensor is leaking have him show you where it is. I assume it is under warranty I would find out if he will warranty it and if not I would suggest a second opinion or go to trane themselves and see what they reccomend.
    I have problems seeing a manufacturer covering a condenser sprayed with sulfur on a daily basis.
    Same as one sprayed with dog piss.
    "Just get it done son."
    Dad adjusted
    Jun 2011
    Hammond,La.
    Quote Originally Posted by hvacvegas View Post
    Clearly, you haven't seen a rotted condenser coil.
    If you have high sulfur and or salt concentration in your water, and that chemical/salt is being sprayed on copper on a dailey basis, I would say it's a posssibility.
    Hard water areas will cause all sorts of bad things to porous metals.
    Jun 2011
    Wake Forest, NC
    Granted, it does sound like there is a leak somewhere in the system. However, just to cover all the bases, make sure the evaporator coil is clean and free of debris. Also, is the ductwork properly sized for the system and the return filters clean? I have seen situations where other companies were dumping refrigerant into a system that had airflow restrictions which were causing it to freeze up. They didn't check the entire system and had added several pounds of refrigerant to a system that wasn't leaking and only needed either new filters or to have the evap coil thoroughly cleaned. Once you have verified that airflow is not a problem then I would say it is time to go on a leak hunt.
    It's not rocket-science...
    It's electromechanical thermodynamic engineering
