Results 1 to 8 of 8
    Jul 2009
    Alabama
    Heat Pump AND Strips Together?
    Does the heat pump and Strips run at the same time?
    Stips is 40 amps, Compressor is say 40 amps,,, Thats 80 amps,,, What a energy wast!
    So, now i have to remove the Contactor from the heat strip supplie wire and add an seperate 10awg wire for the compressor, or use a 2 awg or 3 awg wire.
    Thats just a bunch of garbage!!!!!!
    Jul 2010
    nebraska
    Woops. Thought this was the tech forum.
    I don't know
    Heat strips should only come on when the t-stat calls for them.
    I doubt the outdoor unit is actually drawing 40 amps even if it's 5 tons maximum circuit amperage and running load amps are two different things.
    Jun 2011
    Hammond,La.
    The heat strips are only for emergency/Aux heat when it is too cold outside to effectively draw heat and during defrost cycle. They shouldn't be running during the normal heat cycle.
    "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
    Benjamin Franklin, 1766
    Rochester NY
    Massive dehumidifier you got there boss!
    I don't know
    "They shouldn't be running during the normal heat cycle. "
    They should be running as needed below the balance point while the heatpump operates.
    Emergency and aux heat are not the same when it comes to controls. The former (100% resistance heat with no hp operation) should only be used during extreme cold and breakdowns.
    Jun 2011
    Hammond,La.
    Quote Originally Posted by amd View Post
    Thought that is what I said, just not in so many words. Guess I should be more specific from here out.
    Oct 2007
    Austin Texas
    Just my I would go for at least #8 wire on a forty amp breaker. #10 won't cut it.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
